70 CM ATV CONVERTER
VE3HKS
70 CM ATV CONVERTER
Post by VE3HKS » Thu Sep 23, 2021 12:35 pm
hELLO OM,S
I have a 70 cm converter. on top of it is a sticker with LO= 2400 mhz mod by Pa3weg. Who can explain to me how this thing works. I am trying to receive 70 cm datv on a digital sat tuner. But I cant get it to work. maybe one of you has experience with this thing. Regards Rusty.
Re: 70 CM ATV CONVERTER
Post by G8GKQ » Thu Sep 23, 2021 1:06 pm
Hi Rusty
It could be a SUP-2400 internally. See here: https://wiki.batc.org.uk/images/c/ce/Zi ... QTV_v2.pdf
But it might be something else?
mccla5214
Post by mccla5214 » Thu Sep 23, 2021 8:06 pm
Which mode are you trying to receive DVB-S or DVB-T? Do you know what symbol rate your trying to receive? If it's 2000K or higher on the SR and DVB-T then you can use a standard set top box like the GTMedia 7Pro. Just set up a terrestrial station with manual frequency entry and it will work. If your doing -S or less than 2K symbol rate, the MiniTiouner Express is real easy to get going for receive.
Mike/KA5TDA
