Page 9 of 12
Re: FreeStreamCoder Software to Generate Mpeg-TS Streams >> New V2.75
Posted: Fri Nov 05, 2021 11:19 am
by g4saq
Brilliant, Dominique! Well done and thank you very much.
73, Russ
Re: FreeStreamCoder Software to Generate Mpeg-TS Streams >> New V2.77
Posted: Sun Nov 07, 2021 11:36 pm
by F1EJP
WARNING
CAUTION VERSION 2.75 and 2.76 REPLACED BY 2.77 (high bitrate bug with the new ffmpeg)
Take over all new features with ffmpeg version 4.3 more stable.
Installation of warning message for flow rates greater than 9000kb / s (unstable)
http://www.vivadatv.org//viewtopic.php?f=78&t=866
73 Dominique F1EJP
Posted: Mon Nov 08, 2021 6:12 pm
by M0DTS
I'm not sure if this has been reported before but something to look into..
The situation:
I have freestreamcoder running and sending TS to my pluto.
If i now close freestreamcoder without pressing stop (i know it's wrong but...) the window closes but the exe is still running in task manager.
Often i find out when i start up freestreamcoder again later and press start and it does not work until i press stop then start again.
Sometimes i have seen only the ffmpeg.exe remaining in task manager but not Aut2Exe, when this happens i have two streams being sent to the pluto so the tx is corrupt.
Posted: Mon Nov 08, 2021 11:05 pm
by F1EJP
Hello M0DTS
Thank you for this feedback.
indeed it was an oversight in my code. This is fixed for the next version.
In the meantime, you have to actually exit with the exit button !
73 Dominique F1EJP
Posted: Tue Nov 09, 2021 9:58 am
by M0DTS
Re: FreeStreamCoder Software to Generate Mpeg-TS Streams >> New V2.78
Posted: Wed Nov 10, 2021 4:11 pm
by F1EJP
Small fixes:
- If you close freestreamcoder without pressing Stop, the window will close but the exe is still running in the task manager.
- Debug mode: If you add to the mem.ini file after START = 0 or 1 the variable VIEW = 1 You see the ffmpeg window to view the errors.
http://www.vivadatv.org/viewtopic.php?f ... 3774#p3741
73 Dominique F1EJP
Posted: Mon Nov 22, 2021 8:27 pm
by g4saq
Hi Dominique,
A couple of weeks ago you very kindly sent me a note on the BATC QO-100 chat page to say that I had too many null packets. I have not been able to figure out what to do about this and I will be grateful if you can advise me please.
I am using OBS with the virtual camera plug-in, your Free Stream Coder V2.26 and F5OEO Pluto firmware. I cannot see any way to adjust the video rate as it is all done for me in your great Free Stream.
Best wishes,
Russ, G4SAQ
Posted: Wed Nov 24, 2021 4:23 pm
by F1EJP
Hello Russ
you are the only one to report this problem.
If there is too much null packet it is certainly a difference in parameter setting between the pluto and FreeStreamCoder.
You should have less than 15% Check carefully:
Modulation, Symbol Rate, FEC and Pilot Symbol ?
73 Dominique F1EJP
Posted: Wed Nov 24, 2021 7:38 pm
by g4saq
Hi Dominique,
Thanks for your reply. I am now using Freestream Coder v2.78. I have the following settings: DVB-S2 QPSK Symbol rate 333 FEC 2/3 FEC Frame 64800 Codec H265 Image size 1280x720 Audio AAC 64 FSP 25
For Pluto I have PCR/PTS 800mS PAT 200mS DVBS2 333k/s Pilots off Rolloff 0.35 QPSK 2/3 Long Frame
The Null Packets are anywhere between 12% and 25%.
Your advice will be most useful, thanks.
73, Russ
Posted: Wed Nov 24, 2021 8:04 pm
Russ, you don't have too many null packets if it is 12%. 25% is a bit high but it depends on the picture content. If you are not moving, or showing a static image, then the nulls will increase, but as soon as you move they will reduce. 12% is good. Much lower and you will see overflows.
