Digital decoding when interference is present
Posted: Sat Feb 23, 2008 9:12 pm
Hello DM,
During the DATV test with G8LES on 70cm today i had chance to try several satellite recivers at L band in terms of the recovery after an interfering interuption.
The Porty 2 were not bad, the Technomatic 1500 was excellent , and the 12V sl 1003 from MAPLINS was a real problem, a momentary loss of the incomming signal locked up the decoder. A reselection of the channel restored the decoding.
However the sensitivity was good on the Sl1003, poorest on the Porty2 and highest on the Technomatic but is was billed as a more sensitive L band Rx.
I was pleased to complete the two way with Mike, I needed all the power I could muster, the hill behind me is about 300ft and i amat the 200ft level, I estimate the scatter losses at 35db so not mich left for the remainder of the 30Km to Mike.
The good news is that it worked and the path appeared to be stable, just need to work out how to tilt the 15 element yagi up at 30deg!
Regards Peterb g3pyb
