I am looking for a Real-Time TS Analyser which can receive the TS from my MiniTiouner and analyse it.
I have found TSReaderLite (https://www.coolstf.com/purchase/purcha ... dlite.html) which seems to be able to accept a Multicast or Unicast UDP source...but was not able to set it.
maybe someone more skilled than me can do it!
best 73
de
i2NDT Claudio
i2NDT Claudio
Dalmine, Italia
Dalmine, Italia
Re: Real-Time TS Analyser
Hi Claudio
First, make sure that your MiniTiouner is set up correctly. Here's the right bit of the minitiouneConfig.ini file that I use with v0.9beta8_9:
Then turn on UDP in the panel at bottom right
Then open TSReader Lite, Select Source, UDPMulticast and make the settings as below.
Hope that helps
Edit - Corrected IP address in minitiouneConfig.ini above
; adresse UDP / UDP address
[UDP]
; adresse UDP pour transférer le TS
; UDP address for TS transfer
TS_AddrUDP=230.0.0.1
;TS_AddrUDP=192.168.2.210
; you can try a virtual address if you have no Ethernet or Wifi connexion
;TS_AddrUDP=127.0.0.1
TS_Port=1234
Hope that helps
- TSTL.JPG (39.54 KiB) Viewed 2875 times
thanks Dave,
now it works very well: actually my minitiouneConfig.ini was quite messed up!
now I have to figure out what all these parameters are... but that's a different story! hahaha.
Claudio
Claudio
i2NDT Claudio
Dalmine, Italia
Dalmine, Italia
