OBS to Portsdown batch file for mpeg2 ?
I seem to have mislaid my windows batch file to use the IPTS input on the Portsdown with an mpeg2 TS from OBS.
H264 is no problem but for our local 24cm repeater it needs mpeg2 for a 2MS signal.
Does anyone have a copy they could send me or point me toward where I might find one ?
Also details of the OBS profile would be useful as well.
73 Tim
73 Tim
Re: OBS to Portsdown batch file for mpeg2 ?
Ok seems like I never had a batch file to convert OBS to Portsdown for H262 - only had one for vMix which uses NDI output.
So just for fun I installed the NDI plug in for OBS and tried the vMix to OBS batch file. Th batch file seems to be running ok and producing a stream but no sign of video.
However looking at the TS from ffmpeg on VLC I get just colour bars so guess there's an input mismatch somewhere.
this is my edited file i am using
setting done for
dvb-s2/QPSK FEC 1/4,1/3,3/5,8/9,9/10
dvbs-s/QPSK FEC 1/2,2/3,3/4,5/6,7/8
SR's 66 , 125 ,250, 333, 500 , 1000 , 2000 , 4000
this is still very much a work in progress. i've just added extra variables to it from the original
this is the bitrate calculator
http://www.satbroadcasts.com/DVB-S_Bitr ... lator.html
hope it helps
setting done for
hope it helps
@echo off
rem edited By G7JTT May 2019
rem Feb 2019 by Evariste F5OEO - QO-100 Release 0.9 (Completely rewritten)
rem Started from original tool
rem Idea from Portsdown vmix ffmpeg script
rem ================= SETUP ONCE ===========
set callsign=yourcall
rem Set appropriately
rem set raspi_ip=230.0.0.10
set raspi_ip=192.168.0.37
rem set raspi_ip=10.0.0.1
set ip=%raspi_ip%:10000
rem Print banner
echo obs MPEG-2 Video Encoder for the BATC Portsdown Transmitter
echo ============================================================
echo:
echo Start this script once obs is running, then leave it running
echo:
echo This script was modded by M1CDQ for DVB-S and DVB-S2 are per portsdown fec list
echo this is a work in progres untested
echo dvb-s2/QPSK FEC 1/4 1/3 3/5 8/9 9/10
echo dvbs-s/QPSK FEC 1/2 2/3 3/4 5/6 7/8
echo Look up Video bit rate value for current SR/FEC
echo use the site http://www.satbroadcasts.com/DVB-S_Bitrate_and_Bandwidth_Calculator.html
echo to work out your own choice of SR/FEC combinations. The Netto TS bitrate is what you need but in Kmps so multiply by 1000000 then enter this as your new TSBITRATE
echo Once OBS is set up you can test it's all working with VLC set to receive an network connection on udp://230.0.0.11:20000 and
echo
echo Set the SR and FEC, press Enter for default (previous) values
echo:
:requestSR
if X%SR%==X set SR=250
set defSR=%SR%
set /p SR=Enter SR ( 66 , 125 ,250, 333, 500 , 1000 , 2000 , 4000 ) in KS (%SR%):
set _tempvar=0
if %SR%==66 set _tempvar=1
if %SR%==125 set _tempvar=1
if %SR%==250 set _tempvar=1
if %SR%==333 set _tempvar=1
if %SR%==500 set _tempvar=1
if %SR%==1000 set _tempvar=1
if %SR%==2000 set _tempvar=1
if %SR%==4000 set _tempvar=1
if NOT %_tempvar% EQU 1 goto :requestSR
if X%SR%==X set SR=%defSR%
:requestFEC
if X%FEC%==X set FEC=3/4
set defFEC=%FEC%
set /p FEC=Enter FEC in kS (%FEC%):
set _tempvar=0
if %FEC%==1/2 set _tempvar=1
if %FEC%==2/3 set _tempvar=1
if %FEC%==3/4 set _tempvar=1
if %FEC%==5/6 set _tempvar=1
if %FEC%==7/8 set _tempvar=1
if %FEC%==1/4 set _tempvar=1
if %FEC%==1/3 set _tempvar=1
if %FEC%==3/5 set _tempvar=1
if %FEC%==8/9 set _tempvar=1
if %FEC%==9/10 set _tempvar=1
if NOT %_tempvar% EQU 1 goto :requestFEC
if X%FEC%==X set FEC=%defFEC%
rem Save values for next time
rem If these lines cause errors your system may not support SETX
rem If so just comment them out (use rem)
if not %SR%==%defSR% setx SR "%SR%"
if not %FEC%==%defFEC% setx FEC "%FEC%"
rem Look up Video bit rate value for current SR/FEC
rem use the site http://www.satbroadcasts.com/DVB-S_Bitrate_and_Bandwidth_Calculator.html
rem to work out your own choice of SR/FEC combinations. The Netto TS bitrate is what you need but in Kmps so multiply by 1000000 then enter this as your new TSBITRATE
rem Once OBS is set up you can test it's all working with VLC set to receive an network connection on udp://230.0.0.11:20000 and
rem
rem
rem
if %SR%==66 (
if %FEC%==1/2 set TSBITRATE=60800
if %FEC%==2/3 set TSBITRATE=81100
if %FEC%==3/4 set TSBITRATE=91200
if %FEC%==5/6 set TSBITRATE=101400
if %FEC%==7/8 set TSBITRATE=106400
if %FEC%==1/4 set TSBITRATE=32400
if %FEC%==1/3 set TSBITRATE=43400
if %FEC%==3/5 set TSBITRATE=78500
if %FEC%==8/9 set TSBITRATE=116500
if %FEC%==9/10 set TSBITRATE=118000
if %SR%==125 (
if %FEC%==1/2 set TSBITRATE=115200
if %FEC%==2/3 set TSBITRATE=153600
if %FEC%==3/4 set TSBITRATE=172800
if %FEC%==5/6 set TSBITRATE=192000
if %FEC%==7/8 set TSBITRATE=201600
if %FEC%==1/4 set TSBITRATE=61400
if %FEC%==1/3 set TSBITRATE=82200
if %FEC%==3/5 set TSBITRATE=148700
if %FEC%==8/9 set TSBITRATE=220700
if %FEC%==9/10 set TSBITRATE=223500
if %SR%==250 (
if %FEC%==1/2 set TSBITRATE=230400
if %FEC%==2/3 set TSBITRATE=307200
if %FEC%==3/4 set TSBITRATE=345600
if %FEC%==5/6 set TSBITRATE=384000
if %FEC%==7/8 set TSBITRATE=403200
if %FEC%==1/4 set TSBITRATE=122800
if %FEC%==1/3 set TSBITRATE=164400
if %FEC%==3/5 set TSBITRATE=297300
if %FEC%==8/9 set TSBITRATE=441400
if %FEC%==9/10 set TSBITRATE=446900
if %SR%==333 (
if %FEC%==1/2 set TSBITRATE=306900
if %FEC%==2/3 set TSBITRATE=409200
if %FEC%==3/4 set TSBITRATE=460300
if %FEC%==5/6 set TSBITRATE=511500
if %FEC%==7/8 set TSBITRATE=537000
if %FEC%==1/4 set TSBITRATE=163600
if %FEC%==1/3 set TSBITRATE=218900
if %FEC%==3/5 set TSBITRATE=396000
if %FEC%==8/9 set TSBITRATE=587900
if %FEC%==9/10 set TSBITRATE=595300
if %SR%==500 (
if %FEC%==1/2 set TSBITRATE=460800
if %FEC%==2/3 set TSBITRATE=614400
if %FEC%==3/4 set TSBITRATE=691200
if %FEC%==5/6 set TSBITRATE=768000
if %FEC%==7/8 set TSBITRATE=806400
if %FEC%==1/4 set TSBITRATE=245600
if %FEC%==1/3 set TSBITRATE=328700
if %FEC%==3/5 set TSBITRATE=594600
if %FEC%==8/9 set TSBITRATE=882700
if %FEC%==9/10 set TSBITRATE=893800
if %SR%==1000 (
if %FEC%==1/2 set TSBITRATE=921600
if %FEC%==2/3 set TSBITRATE=1228800
if %FEC%==3/4 set TSBITRATE=1382400
if %FEC%==5/6 set TSBITRATE=1535900
if %FEC%==7/8 set TSBITRATE=1612700
if %FEC%==1/4 set TSBITRATE=491200
if %FEC%==1/3 set TSBITRATE=657400
if %FEC%==3/5 set TSBITRATE=1189300
if %FEC%==8/9 set TSBITRATE=1765500
if %FEC%==9/10 set TSBITRATE=1787600
if %SR%==2000 (
if %FEC%==1/2 set TSBITRATE=1843100
if %FEC%==2/3 set TSBITRATE=2457500
if %FEC%==3/4 set TSBITRATE=2764700
if %FEC%==5/6 set TSBITRATE=3071900
if %FEC%==7/8 set TSBITRATE=3225500
if %FEC%==1/4 set TSBITRATE=982500
if %FEC%==1/3 set TSBITRATE=1314900
if %FEC%==3/5 set TSBITRATE=2378600
if %FEC%==8/9 set TSBITRATE=3530900
if %FEC%==9/10 set TSBITRATE=3575300
if %SR%==40000 (
if %FEC%==1/2 set TSBITRATE=3686300
if %FEC%==2/3 set TSBITRATE=4915000
if %FEC%==3/4 set TSBITRATE=5529400
if %FEC%==5/6 set TSBITRATE=6143800
if %FEC%==7/8 set TSBITRATE=6451000
if %FEC%==1/4 set TSBITRATE=1964900
if %FEC%==1/3 set TSBITRATE=2629700
if %FEC%==3/5 set TSBITRATE=4757200
if %FEC%==8/9 set TSBITRATE=7061900
if %FEC%==9/10 set TSBITRATE=7150500
echo Video bitrate for %SR% kS and FEC %FEC% is: %TSBITRATE%
echo:
echo Press any key to start the TS stream
echo:
pause
echo launch ffmpeg OBS
start "OBS to udp/ts" /high ^
C:\ffmpeg\bin\ffmpeg ^
-i udp://230.0.0.11:20000 -c:v copy -max_delay 1000000 -muxrate %TSBITRATE% -c:a copy ^
-f mpegts -mpegts_original_network_id 1 -mpegts_transport_stream_id 1 -mpegts_service_id 1 -mpegts_pmt_start_pid 4096 -streamid 0:256 -streamid 1:257 ^
-metadata service_provider="BATC" -metadata service_name=%callsign% ^
-flush_packets 0 -f mpegts "udp://%ip%:10000?pkt_size=1316&bitrate=%TSBITRATE%"Re: OBS to Portsdown batch file for mpeg2 ?
Thanks for the batch file - I was just about to post that I'd found what the problem is with NDI on OBS, basically prefixes the ndi stream the name of the PC which causes dshow to choke - so your batch file may get me out of this hole !
However could you provide the settings you use on OBS for the recording output as mine doesn't seem to work.
The batch file finds the OBS stream and runs ok but the MT rx doesn't decode the stream - so I guess its an OBS recording output setting.
Many thanks again, Tim
edit I had my OBS output set to H264, switching it to mpeg2video has resulted in getting the meta data but no video so far - strangely MT rx reports the codec as H264 but VLC reports it as mpgv - clearly I have something wrong in the OBS profile for mpeg2 !
https://wiki.batc.org.uk/OBS_-_Open_Broadcast_Studio
this is where i started in setting up profiles in obs
yeah - thanks for the link. I had tried that but it is for H264 rather than H262.
Think I'll give up for now and have a fresh look tomorrow as it's clearly an OBS profile problem - maybe a glass of wine will help
Thanks again Tim
Thanks again Tim
