Minitiouner UDP to OBS
G4WIM
Post by G4WIM » Fri May 31, 2019 3:12 pm
Hi guys,
I have Minitiouner generating a multicast signal which can be decoded using VLC on a stand alone PC but what I'm trying to do is to get OBS to accept the stream from Minitiouner.
Looks like OBS can't handle udp as an input stream.
Does anyone have the secret sauce to allow Mintiouner to talk to OBS ?
Regards Tim
G7JTT
Re: Minitiouner UDP to OBS
Post by G7JTT » Sat Jun 01, 2019 4:19 am
Easiest way is to run VLC on the same pc as OBS then window grab the contents. I do similar to this as OBS won't play videos as a source (just black screen) so I play videos within VLC then grab that as a source.
All best John G7JTT
G4WIM
Post by G4WIM » Sat Jun 01, 2019 11:45 am
Hi John,
thanks for the tip - working nicely now.
I had been try to 'sheep dip' the MT udp stream thru' VLC to convert it to RTSP or some other protocol which OBS could handle but didn't get very far.
73 Tim
gi7ugv
Post by gi7ugv » Sat Jun 01, 2019 8:01 pm
OBS will take a UDP output from Minitioune if needed, I'm having to do this as I'm using different computers for OBS & Minitioune.
It's not perfect though, sometimes it doesn't work or does not pick up on changing what you're receiving. Removing the source and adding it again seems to give it the kick it needs but it's a pain.
In OBS sources add a "VLC Video Source" add a playlist source and "add Path/URL" then enter the UDP URL you're using. The working UDP input from the beacon is shown below.
