RDA5815 Interesting all in one tuner IC.
2W0ODS
Post by 2W0ODS » Sun Nov 25, 2018 7:52 am
This looks a very interesting all in one tuner on one IC, it can tune down to 250MHz and does not require a balun or much supporting hardware.
I think one of my satboxes has one of these so going to have a play around, certainly useful for Es'hail2 if I can get it to go sub 950MHz, but more interestingly is building something Minitioune compatible or similar.
http://www.mjdic.com/news-read-id-451.html
Re: RDA5815 Interesting all in one tuner IC.
Post by G4GUO » Sun Aug 02, 2020 5:31 pm
I have recently had to write some code to control that chip and while the datasheet says it will go down to 250 MHz
the programmers guide and the register map I have don't show you how to program outside of the standard
950 MHz to 2.1 GHz range sadly.
P.S YesI know your original post was from almost 2 years ago (I am just a bit slow).
avdeev_av
Post by avdeev_av » Mon Sep 27, 2021 10:18 am
Hello Charles! You have the documentation for the RDA5815. I really need it. Could you share with me.
Post by G4GUO » Mon Sep 27, 2021 8:37 pm
I have sent you a dropbox link via a PM.
jvars
Post by jvars » Tue Feb 15, 2022 3:59 pm
Hi Charles,
I am also looking for RDA5815 programming guide. If you still have it, would you mind sharing it with me too?
