The Short Version
I'm using ffmpeg on a RPi3 to generate an H264 transport stream using either libx264 or h264_omx and mpegts. I can get it to work properly with libx264, but the CPU is maxed out. With h264_omx it appears to work, but the resulting TS has an undefined frame rate. VLC will play the TS, but it is unsuitable for transmission using the DVB-S standard. I know that h264_omx is at least functioning, because it works with flv output.
I realise that this a very specialist question and I am not expecting answers - just pointers to where I might find any more information on how to force mpegts to define the frame rate. Google has not been helpful!
The Long Version
This code to produce a web stream using ffmpeg, libx264 and flv works well but maxes out the CPU:
/home/pi/rpidatv/bin/ffmpeg \
-f v4l2 -input_format h264 \
-i /dev/video0 -thread_queue_size 2048 \
-f alsa -ac 1 -ar 44100 \
-i hw:1,0 \
-framerate 15 -video_size 720x576 -c:v libx264 -b:v 512k -minrate:v 512k -maxrate:v 512k \
-b:a 22050 -ac 1 \
-g 25 \
-f flv rtmp://sitename.org.uk/live/keykey &
-i hw:1,0 \
-framerate 15 -video_size 720x576 -c:v h264_omx -b:v 512k -minrate:v 512k -maxrate:v 512k \
-b:a 22050 -ac 1 \
-g 25 \
/home/pi/rpidatv/bin/ffmpeg -loglevel debug \
-f image2 -loop 1 -pix_fmt yuv420p\
-framerate 25 -pix_fmt yuv420p \
-i /home/pi/rpidatv/video/tcf.jpg \
-c:v libx264 -pix_fmt yuv420p \
-b:v 320600 -minrate:v 320600 -maxrate:v 320600 \
-f mpegts -blocksize 1880 \
-mpegts_original_network_id 1 -mpegts_transport_stream_id 1 \
-mpegts_pmt_start_pid 4095 -streamid 0:256 -streamid 1:257 \
-metadata service_provider=G8GKQ -metadata service_name=G8GKQ \
-muxrate 1382352 -y videots &
If I substitute h264_omx for libx264, it runs with lower CPU usage, but produces a non-compliant transport stream with a (video) frame rate undefined:
-c:v h264_omx -pix_fmt yuv420p \
I also tested with writing the output to a .ts file and using Promax TS Analyser software to look at the stream properties. It said that the (video) frame rate in the h264_omx stream was 0.0 fps. VLC played both files OK, but when checking codec properties, there was no entry for the frame rate in the h264_omx-produced file. In the libx264 file the frame rate was correctly described as 25.0 fps. I think that this is the reason it does not work in my application - so I am looking for a way to make mpegts define the (video) frame rate.
Here is my ffmpeg configuration:
ffmpeg version 3.3.2 Copyright (c) 2000-2017 the FFmpeg developers
built with gcc 4.9.2 (Raspbian 4.9.2-10)
configuration: --prefix=/home/pi/ffmpeg_build --pkg-config-flags=--static --extra-cflags=-I/home/pi/ffmpeg_build/include --extra-ldflags=-L/home/pi/ffmpeg_build/lib --enable-gpl --enable-libfreetype --enable-libmp3lame --enable-libx264 --enable-libx265 --enable-nonfree --enable-mmal --enable-omx --enable-omx-rpi
libavutil 55. 58.100 / 55. 58.100
libavcodec 57. 89.100 / 57. 89.100
libavformat 57. 71.100 / 57. 71.100
libavdevice 57. 6.100 / 57. 6.100
libavfilter 6. 82.100 / 6. 82.100
libswscale 4. 6.100 / 4. 6.100
libswresample 2. 7.100 / 2. 7.100
libpostproc 54. 5.100 / 54. 5.100
The software is intended to be an enhancement to the Portsdown Transmitter: https://wiki.batc.tv/The_Portsdown_Transmitter The existing code is on GitHub here: https://github.com/BritishAmateurTelevisionClub/rpidatv
Thanks in advance
