Just a query on how you can use leandvb with the adalm-pluto?
It there a howto or FAQ on this. I suspect one needs to build leandvb for the pluto and feed the results out to other devices.
I have seen the video of this being done but can't find any details to replicate it.
Many Thanks
Peter
G4DCP
Leandvb and ADALM-Pluto
Re: Leandvb and ADALM-Pluto
Yes, you can compile leandvb on another ARM machine such as a Raspberry Pi and run the statically-linked binary on a Pluto. This is similar to what I recommended for using leandvb on Outernet embedded receivers:
http://www.pabr.org/radio/leandvb-satmo ... .html#chip
You will also need a command-line utility to capture IQ and feed it into leandvb; iio_readdev or ad9361-iiostream in the libiio source tree is a good start.
Hopefully I will release howto articles and an easy-to-use solution with pre-compiled sdcard images before the next batch of devices ships (mid November according to Mouser). Having an onboard CPU that can serve a web GUI is definitely a game changer for low-cost SDR.
Many Thanks I will give that a try!
Peter
Peter
