DATV with zero-latency hifi stereo audio ?
Posted: Fri Jul 07, 2017 9:14 am
Dear forum,
Several, if not most, FM ATV repeaters in NL use, in addition to 2 (or more) FM audio carriers, a Nicam sub-carrier for hi-fi stereo sound.
So does PI6ALK.
At PI6ALK vision and sound quality is one of the main drivers, as well as cross-band full-duplex operations with multiple users. (Typical operation looks like a video conference. At busy times people compare it to a cafe.)
At PI6ALK we are currently contemplating a move to DATV, but most users, although interested in technical progress (e.g. HD), expressed their concern with the latency in the audio that comes with the 'traditional' DATV implementations. Video latency and lack of lip-sync is considered not a big issue, but >500ms delay (Tx+Rx) in audio is expected to kill interactive discussions.
So, the challenge is to devise and implement a DATV mode that provides the best of both worlds; HDTV and zero-latency hi-fi audio. There are a few boundaries to an implementation:
- reasonably easy to build/implement Rx for users of PI6ALK (and users of other repeaters that might wish to follow this route)
- not require more RF bandwidth than the currently occupied 27 MHz
- not require more RF Tx power (We realize that a digital solution will require a higher power PA (in back-off), or some kind of linearization scheme, which is fine)
Current, fully untested, ideas are:
1. to include Nicam bits in the transport stream and somehow get them out at the Rx-end to be decoded in a Nicam decoder chip or a dedicated DSP.
2. to add a NIcam subcarrier to the DVB-S(2) TX signal and Rx-ed like a normal FM-ATV signal with Nicam sub-carrier
Any more from you forum readers?
Regards,
Herman, PE1GTA/PI6ALK
So does PI6ALK.
Regards,
