DATV Express bugs report
Posted: Sun Dec 11, 2016 9:21 am
My first constraint : I only want to use the DATV express under Windows environment.
I only use my DATV Express once every 2 or 3 months and put it away, saying that each time I use it, I loose too much time and get bad results or have to spend time because of bugs ( "French bug", installation bug, "TS data rate" bug...)
(But yes, this hardware could do a fantastic job...)
I use it only sometimes ...
1)Mainly because I need to do some test for friends that ask me to implement new possibilities to Minitioune software.
Now the new version of Minitioune can receive DVB-S2 and also decode H265. (it will be soon available)
2) Because I always think that I cannot make the DATV Express work as I hope ( = correctly in my mind)
a)I have spent many hours to make it recognized on a computer where I had already installed a similar driver for a Technotrend USB tuner ( S-2400 or S2-3600 ) and each time I plug the DATV express it is recognized as a TT USB device!!! I have tried all I can know, deleting all I can find about TT USB in the base registers.... I have not found the solution.
This is the only hardware that gives me this kind of result.
If someone can give me the solution, thanks
b) On another computer, it is recognized and seems to work but
- I cannot make it work in DVB-S2 mode . I know that there is something to do to fix this, but don't remember and don't find where there is the solution, nothing in the DATV express website, nothing on the notes_V1.23.txt.
I really prefer to continue to use the DATV express server as I can create myself the good TS I like.
the Express transmitter software (v1.23) has too much bugs, that doesn't allow to use it more that 1mn
The biggest bug I think is the TS rate computed : If I set SR2000 kS/s fec 3/4, I see on the panel that the Tx bitrate will be 3.000 Mbps.
It is a bad computed value. The good value should be : 2000 x 2 x 3/4 x 188/204 = 2764.7 kbps
So the Datv Express transmitter software send a TS that has a Symbol rate with a big jitter ( I can see it when I use Mintioune in expert mode) with a data rate that doesn't correspond to the SR we should have . If I record the TS with Minitioune and use this TS with any TSplayer/analyzer (StreamXpres..), they say that the TS rate is effectively 3000 kbps but that the SR corresponding, using fec3/4, is SR2170 kS/s, not SR2000!!
So, when I use Minitioune to decode directly the TS transmitted by the DatvExpress transmitter software, I begin to decode, but loose the sound after some tens of second of sometimes some freeze... There is some difficulties to synchronize the sound and the video and the more i wait,the more is the de-synchronization.
So, for me, the biggest bug is firstly this bad data rate.
I am the only user that has this result? Is it only a bad installation on my computer?
I really wonder because I don't understand that other users seem to not have this issue as it has never been reported...
Perhaps I have missed something? As anybody, sometimes I can be stupid.
Whishes:
- As I really like to work Narrow band DATV, I would like also to find
>> the mono 32kbps data rate for the Mpeg Audio codec
>> the possibility to tweak ffmeg parameters.(?) I don't know if the bad result ( video freeze ...) I have using low SR, comes from the ffmepg encoding or from the data rate bug I have talk above.
>> the possibility to use my own graph, or use an UDP input. (I don't like very much ffmpeg).
When I use the DATV express ServerApp, I can create myself a good TS with the good data rate, choose 20 fps for the webcam (not the encoding rate), set the Mpeg2/H264 encoder for the best result I can.
So this for me the only way I can use in good condition my DATV express. ( but no DVB-S2 possibility...)
Last tests show me that I could use the DATV Express with only a Pipo (C615 capture +H264 encoding /decoding and display use only 35% CPU - )
YES, this hardware could do a fantastic job..
Jean-Pierre F6DZP
Whishes:
Jean-Pierre F6DZP
