437MHz success !
Posted: Sat Mar 21, 2015 2:26 pm
by G4WIM
G3UVR on the Wirral managed to rx my 437MHz DATV transmission from IO83LR (Lytham) and I was only running 125mW also got a D5 report from G1LWX Mike located at Ashton-in-Makerfield.
Not managed to rx anyone though which is a little worrying even though the rx seems to work down to -106dBm on 437 and - 105.5dBm on 1248MHz.
I can see my out going signals ok.
I was wondering what others get rx sensitivity wise ?
73 Tim G4WIM
Re: 437MHz success !
Posted: Sat Mar 21, 2015 5:24 pm
by g8gtz
Hi Tim,
It is probably not just a matter of sensitivity - the SUP 2400 needs quite a bit of gain in front of them but more likely need some good filtering as there's a lot of (very loud) rubbish around on 70cms.
Take a look at
http://www.batc.org.uk/forum/viewtopic.php?f=15&t=3704 for more ideas...
Posted: Sat Mar 21, 2015 6:31 pm
by G4WIM
HI Noel,
thanks for the link - as it happens I had stumbled across that one already.
As for my rx line up it is a SUP2400 preceded by a BATC 435MHz bandpass helical filter which is fed by a WJ LNA about 1.5dB NF and 15dB gain not sure what the IP is though.
I also have a DCi filter for both the tx and rx path but have not put that in circuit yet - maybe it is something out of band blocking the rx and hopefully the DCi filter will fix it. It's this 4 pole 10MHz bandwidth one - 0.3dB insertion loss and can handle 200 watts
http://www.dci.ca/?Section=Products&SubSection=Amateur
73 Tim
Posted: Thu Mar 26, 2015 9:02 am
by pbg3pyb
Hello Tim g4WIM
Re sensitivity of 70cm DATV, hope the following helps.
I have an permanently connected low level signal injection on my DATV Rx using a -29db coupler.
The RX line up is g4DDK pre amp, 8MHz (to 3db points)6 pole filter with side notches set to reject 433 area. C/F is 437 and out of band is good.
Convertor is home made with SBL mixer IF is 1525Mhz gain across convertor is 38db ...437 to 1525.
I use a Toutune and a Technomate 1500 on a splitter.
The Technomate lock threshold is -114dbm and the Tutoune about 3db poorer.
In this mode my antenna is connected so I see antenna and site noise, when I beam at he local hospital threshold drop by up to 4/5db but towards France over the see its quite and the -114 level is reliable. I see Frence Sysedis (not the correct spelling) quite often in the direction of Cherbourg.
Without the notches the whole system is much poorer.
Regards Peter g3pynb
Posted: Thu Mar 26, 2015 7:25 pm
by G4WIM
Hi Peter,
thanks for the feedback on your system.
I suspect my 437MHz front end is quite good and the sup-2400 is not the limiting factor - I'm beginning to think my Samsung STB might be rather critical as to what it'll decode. I have a good 437MHz band pass made by DCI to keep jammers out of the pass band.
The STB is a SMT-S7800 - quite high spec device I've borrowed from the lounge, maybe a lower spec device might have a lower threshold !
Will have to get my hands on another STB and see how it compares - especially as it looks as though I might be nearly 10dB adrift - probably the same on 24cms as well.
73 Tim G4WIM
