Hi All,
Just been given an amplifier with one of these units inside and plan to use it with DVB-S RF, so it is requiring it to be used as a linear.
Can only find a single page data sheet on the web, so have no idea how the unit needs to be biased.
GB3TM uses one of these modules (http://www.arfon.info/GB3TMDigital.htm - see fig 6) so my quest appears to be reasonable.
Current amplifier is designed for FM and has pin 1 as RF in, pin 2 as 13V, pin 3 as 8v, pin 4 as 13v, and pin 5 as RF out.
Quiecent current appears to be 640mA at 13V with input and output terminated in 50R.
Amplifier appears to be unstable, but ground straps were not included from module substrate to PCB ground plane. Also, there a couple of high value electrolytics on the 13V rail that could have easily dried up.
So before the unit is disassembled and fixed, a full datasheet would be most appreciated. Or some indication if the supplies above are OK for linear operation. I appreciate that the unit will probably only generate a couple of watts for this mode.
Any help appreciated.
-Mark
23cm DATV PA - Mits. M68719
Jump to
- Forum Admin
- ↳ Announcements
- ↳ Feedback
- ATV General Discussion
- ↳ Getting Started?
- ↳ General ATV Discussion
- ↳ DATV - Digital ATV
- ↳ ARISS HamTV
- ↳ LimeSDR Mini
- ↳ CAT 25 Part 1, 3 August 2025
- ↳ CQ-TV, The BATC Magazine
- ↳ BATC Bursary Grants
- ↳ Spectrum matters
- ↳ Streaming
- ↳ EMF Compliance
- ↳ Narrow Band DATV (RB-TV)
- ↳ DXSpot.TV
- ↳ Deutschsprachiges Forum
- ↳ Events
- ↳ DigiThin
- ↳ DigiLite
- ↳ BATC DTX1
- ↳ CaribouLite RPi Hat
- Adverts
- ↳ For Sale
- ↳ Wanted
- ↳ BATC Shop
- ATV Repeaters
- ↳ UK ATV Repeaters
- ↳ GB3BH
- ↳ GB3CZ
- ↳ GB3DK
- ↳ GB3EN
- ↳ GB3ET
- ↳ GB3EY
- ↳ GB3FB
- ↳ GB3FT
- ↳ GB3FW
- ↳ GB3FY
- ↳ GB3GG
- ↳ GB3GV
- ↳ GB3GW
- ↳ GB3HV
- ↳ GB3IF
- ↳ GB3IT
- ↳ GB3IV
- ↳ GB3JT
- ↳ GB3KM
- ↳ GB3LO
- ↳ GB3LX
- ↳ GB3MV
- ↳ GB3NQ
- ↳ GB3NV
- ↳ GB3PV
- ↳ GB3RT
- ↳ GB3RV
- ↳ GB3SQ
- ↳ GB3TG
- ↳ GB3TM
- ↳ GB3TN
- ↳ GB3TT
- ↳ GB3TV
- ↳ GB3TZ
- ↳ GB3UD
- ↳ GB3VR
- ↳ GB3UT
- ↳ GB3VL
- ↳ GB3VV
- ↳ GB3VX
- ↳ GB3WV
- ↳ GB3YT
- ↳ GB3ZZ
- ↳ Internet-only Repeaters
- ↳ IO91LC
- ↳ IO91WN
- ↳ IO92GQ
- ↳ Overseas ATV Repeaters
- Archive
- ↳ GB3AT
- ↳ GB3FT
- ↳ GB3FV
- ↳ GB3CT
- ↳ GB3AD
- ↳ GB3BG
- ↳ GB3DH
- ↳ GB3DJ
- ↳ GB3KT
- ↳ GB3NV
- ↳ GB3OT
- ↳ GB3PT
- ↳ GB3TB
- ↳ GB3TX
- ↳ GB3VW
- ↳ GB3XG
- ↳ GB3XT
- ↳ GB3XV
- ↳ GB3XY
- ↳ GB3YT
- ↳ GB3YX
- ↳ For Sale Ads Archive
- ↳ Wanted Ads Archive
- ↳ CAT 16 and BGM 2016
- ↳ CAT 17
- ↳ CAT18
- ↳ Mini-Conventions in 2019
