70cms DATV activity list
Posted: Tue Nov 19, 2013 8:58 am
by g8gtz
I thought it would be a good idea if we started a list of those active on DATV on the various bands, so please respond to this topic giving details of your station if you are active on 70cms DATV only - perhaps someone else can start a new topic for 23cms and other bands.
G8GTZ - IO91KH - Basingstoke
19 ele Tonna at 10mts with SPF 5043 mast head pre-amp
125 watts on 437 MHz - preferred 1/2 FEC
SUP2400 feeding DM500 Dreambox receiver plus Tutioune - monitor available at http://www.vivadatv.org/tutioune.php?om ... ation_id=1
170 mts ASL with good take off in all directions apart from to the South West.
Re: 70cms DATV activity list
Posted: Fri Nov 22, 2013 9:32 am
by G8DKC
Hi All,
TX , 437mhz, 50w, at the moment, to a 7 Element ZL Special, planning problems, SSSI again!, when inc aerials for 23cms.
Trx 70w on 144.750 collinear.
Location IO92GQ, in Google Maping terms, top, and end of M42 / A42 start, Nr Measham.
Fair take off to South & South West on slightest lift.
Rx at the moment, I use GB3GV, Far better take-off than me, favors South East, South & South West, 14Km to the East of me.
GB3GVs Location, IO92IQ, North West of Leicester.
Use Tutioune at home not yet on site or the Internet.
Peter
Posted: Fri Nov 22, 2013 10:18 am
by M0DTS
M0DTS - IO94IL - Nr Middlesbrough
25 ele K1FO Yagi at 10mts with SPF 5043 mast head pre-amp
80 watts on 437 MHz - 3/4FEC (Limited by AGAF Tx), DigiLite on 70cm is progressing slowly.
SUP2400 feeding Usually the Comag SL100HD, alternatively PC card with Tutioune but not reliable on my Win7 64bit pc.
Little to no change of me receiving anyone at home due to Fylingdales Interference but i'm happy to tx any time!
60 mts ASL with good take off to most places apart from South round to East.
More likely to hear me from /P site IO94MJ on the North Yorkshire Moors.
Posted: Fri Nov 22, 2013 10:18 pm
by G0KTD
G0KTD IO70OI St Austell
19 Element Tonna 8mtrs
150 watts on 437Mhz 3/4 FEC Tandberg unit ( DigiLite on 70cm is progressing slowly )
Mini-Kits Preamp SUP 2400 Feeding Comag Sl 30/12.
QTH 232 ASL Poor take off to the North and part of the East good sea path to France etc
Posted: Thu Dec 19, 2013 10:34 am
by rayatbatc
ray g8jbq
location -south perrott (near crewkerne somerset)
good path to north ,all other directions poor
soon to set up sup 2400 on recieve
looking for contacts
Posted: Fri Dec 20, 2013 4:20 pm
by g8cpf
G8CPF in Minehead....
Active on 437MHz DATV 2MS/s with appx 40w to a 10 el yagi.... Usually beaming NE up the Severn Estuary, but have reasonable takeoffs from NW (Swansea/ Neath) through N (Cardiff), NE (Bristol), E (Somerset levels), SE (Taunton)....... Monitor 144.750MHz regularly........
Might have a chance to you Ray (G8JBQ) in South Perrott...... will listen for you on '750.
de Mike in Minehead G8CPF
Posted: Fri Dec 20, 2013 6:35 pm
by M0ATV
M0ATV Stockport IO83WJ Monitor 144.750 FM always, & G0SPH Stream (24/7)
19 Element Tonna 70cm 60w DATV DTX1 SUP2400 HA8ET Contest Preamp (Tuned to 437Mhz)
44 Element Wimo 23cm 150w DATV DTX1 Comag SL-30/12 DB6NT Preamp ( Analogue TX as well )
QTH 125m ASL Poor take off to the East, shielded to SE
