ISS on 13cm
g4bbh
ISS on 13cm
Post by g4bbh » Tue May 14, 2013 5:33 pm
I notice ISS is to transmit DVB-S ATV on 13cm. http://amsat-uk.org/2013/05/12/hamtv-from-the-iss/
I don't yet have any kit for that band, only the DVB-S receiver I usually use on 23cm. I have a down converter that would bring 13cm down to around 23cm. Is that likely to be the best route?
Dick G4BBH
Re: ISS on 13cm
Post by M0DTS » Thu May 16, 2013 12:21 pm
Yes,the down converter is probably the only option as you need to use your sat receiver to decode the DVB-S.
Re: ISS on 13cm
Post by G4EWJ » Thu May 16, 2013 1:47 pm
Some receivers are only specced down to 2M symbols/s, so 1.3MS/s (SR1300) may be a problem.
g4bbh
Re: ISS on 13cm
Post by g4bbh » Sat May 18, 2013 6:06 pm
I had missed the symbol rate. Wonder why they chose 1.3Ms/S. It might be difficult to find anything (cheaply) that does.
Would be MUCH more interesting if they took up a complete DATV repeater.......
Dick
Re: ISS on 13cm
Post by G4GUO » Sun Jun 09, 2013 7:16 am
For anyone building their own receive converters for the ISS these bandpass filters look ideal.
http://www.rf-microwave.com/eng/catalog ... SU-97.html
