DATV-Express Project – March update report
KenW6HHC
Post by KenW6HHC » Sat Mar 30, 2013 2:20 pm
Art WA8RMC finished performing the basic electrical tests with the “testing software” on the new “first-article” prototype PCBA and found everything working as planned. Art was successful in producing 18.6 dBm of output on 1.3 GHz in early March…and then sent the board to Charles G4GUO to begin more thorough testing and to begin making some software changes.
Charles had the new board transmitting DVB-S and DVB-S2 video within a couple of hours after Parcelforce delivered the box to his QTH. Charles’s first reports included:
• Min operating frequency 72.5 MHz
• Max operating frequency 2.48 GHz
• Noise sidebands -55db (about 30db better than previous board)
• Very clean QPSK constellation
First DVB-S pictures received from new board layout
On the left is the clean QPSK Constellation from new second board layout.
On the right is the noisy QPSK Constellation from original board etch layout.
During March, Charles was able to accomplish quite a lot of improvements to the DATV-Express software design, as he has summarized below:
Host code
• Now being compiled under Ubuntu 12.04 LTS
• Development environment has been updated to Qt5.01 Creator
FX2 code
Added proper support for USB2 VBUS monitoring
FPGA code
• Interpolation increased from x4 to x8
• Pulse shaping filter increased to 95 taps (root raised cosine compensated response).
• Programmable symbol rate generator added with the current range 2 MS/sec to 6 MS/sec in fractional steps.
• I2C configuration of modulation parameters has been added
• Delayed IQWRT clock added.
• DAC has so far been tested up to 48 Msamples/sec
No etch errors have been found in the second layout, so huge compliments are deserved by our PCB layout guru, Tom WB6P. Art WA8RMC is busy building up a second prototype board. Charles also has plans to get the entire DVB-S protocol to run on the FPGA rather than on the Linux host PC. That way…the whole host thing can also be run on a small ARM-based computer, like a Raspberry Pi or perhaps the MK808.
Spectrum of new board with 1.299 GHz unmodulated carrier signal
In his spare time, Charles G4GUO has completed a new YouTube video to describe
the DATV-Express Version 2 PCBA at http://youtu.be/OXh-anABYaU
"full speed ahead"...de Ken W6HHC
F4HDK
Re: DATV-Express Project – March update report
Post by F4HDK » Sat Mar 30, 2013 3:03 pm
Thank you. Its a great project. It looks like a professionnal product!
Do you plan to add all the DVB processing inside the FPGA, instead of inside the PC currently? Like for the Digilite-ZL project?
It would be a good Idea for making a standalone DATV repeater for example. The DATV-Express board would have to accept a raw "Transport Stream" signal.
Thanks for your answer.
Guillaume - F4HDK.
Post by G4GUO » Sat Mar 30, 2013 5:24 pm
Guillaume,
DVB-S will be in the FPGA, I am working on that at the moment.
DVB-S2 won't be as it requires too much memory.
The application downloads the appropriate FPGA and USB FX2 firmware depending on the mode.
So the board can have multiple personalities. One day I will get it working on SSB.
- Charles G4GUO
