MPEG2 Encoder V5
MiniMOD 3 (70MHz – 2200MHz) with DVB-S and DVB-T
MiniKey controller (with keys and LEDs under the display)
This package is known as the Hamset-3 and is available at 500 euros plus 19% VAT (works out at approx £500 with P+P).
This is a very good deal for the boards, which work very well and give you instant transmit capabilities on 70cms and 23cms plus a video sender capability using DVB-T to all those Freeview boxes around the home - that should help with the XYL justification
The output is approximately 0 dBm AND NEEDS FILTERING plus power amplifiers - see the forum chat re the MHW7317 modules for 70cms.
This offer is available direct from SR systems by ordering a "Hamset -3" using the email address datv@sr-systems.de - Dealing with SR systems can be a little challenging but persevere. Documentation is somewhat lacking but can be found at:
Product data sheets =
http://sr-systems.de/content.php?show=M ... &style=std
http://sr-systems.de/content.php?show=D ... &style=std
User guide (note this covers the alternative front panel layout but function is the same)
http://www.maintech.de/fileadmin/Downlo ... sGuide.pdf
FYI - I have no commercial ties and can offer no support - just passing the message on
Don't forget, if you want a finished unit in a shiny box - see Justin G8YTZ's advert in the latest edition of CQTV...
