ADALM-PLUTO (new DATV SDR)
G8PEF
Post by G8PEF » Sat Jan 27, 2018 7:32 am
Yikes, Peter! June?
When did you place your order?
It might be worth investigating Mouser - they have 2 shipments due (Feb, as above, and March). Mine (only ordered 3/1/18) is still scheduled to be shipped from the first batch, so you might be able to get one a lot sooner than June.
PEF
Post by G4GUO » Sat Jan 27, 2018 10:18 am
Analog Devices also produce a couple of add on boards (~£200)
AD-TRXBOOST1-EBZ 0.8 dB receive preamp/100 mW PA
AD-FREQCVT1-EBZ-ND frequency translator that allow the unit to operate below 70 MHz
https://wiki.analog.com/resources/eval/ ... l_overview
Although they are aimed at the FMCOMMS1/2/3/4 devboards they should work just as well with the Pluto.
The only issue I can see is that they need and SPI input to control the synth.
I suspect someone could make a little add on board using cheap Chinese dev boards for less money.
G8DKC
Post by G8DKC » Mon Jan 29, 2018 7:44 am
Well G8PEF,
Looks like I have a delivery date of FEB 20, 2018...
Then I can try out Charles's good works!
And a spare in June if Digikey comes through.
Thanks for the tip.
Peter
G8PEF
Post by G8PEF » Mon Jan 29, 2018 9:43 pm
Good stuff, Peter
Unless you really want a 2nd one, you could always cancel the Digikey order.
John
G8PEF
Post by G8PEF » Wed Feb 07, 2018 7:17 am
Mouser have now updated the expected delivery date to 25 Feb - has yours gone to the same date, or later, Peter?
John
G4FRE
Post by G4FRE » Wed Feb 07, 2018 9:57 am
Mouser just updated my delivery estimate to Feb 20 2018, we will see if it happens
G4FRE
G8DKC
Post by G8DKC » Thu Feb 08, 2018 7:54 am
Mine has now gone to the 27th Feb....
Peter
Post by G4GUO » Sat Feb 10, 2018 4:40 pm
The Analog(ue) Devices website is quoting the 15th Feb 2018.
Post by G4GUO » Mon Feb 12, 2018 6:33 pm
From the ADI EngineerZone
"This was required since the current 256Mbit Micron flash is currently out of stock anywhere.
(That's BTW causing the long production delay for the next batch of ADALM-PLUTO)
We're now building a batch using the 512Mbit replacement type..."
So now you know!
G8DKC
Post by G8DKC » Wed Feb 14, 2018 9:14 am
Latest on the Great Pluto Saga....
My Mouser delivery moved from 27th Feb to 20th Feb...
Aha...
