DATV-Express Project - January update report
on7ma
Re: DATV-Express Project - January update report
Post by on7ma » Thu May 12, 2016 10:28 am
Ok Evariste , I will do...
TS out from the Windows Program TX , or RX record from Minitoutioune , you mean ?
Tnx
JP, ON7MA
f5oeo
Post by f5oeo » Thu May 12, 2016 10:37 am
Could be recorded from tutioune to be sure what exactly is received.
30 seconds to 1 minute should be fine.
on7ma
Post by on7ma » Thu May 12, 2016 12:52 pm
Hi Evariste
here's the stream, just recorded with minitiouner.
https://www.dropbox.com/s/czlk6kn3ts819 ... 29.TS?dl=0
Meanwhile ,i 'm sending with version 1.07 made yesterday by Charles, with the possibility to code audio at 192Kbits, to see if that improved audio, on the VU+, or Dreambox, which did not
Tnx for concern
JP, ON7MA
f5oeo
Post by f5oeo » Thu May 12, 2016 1:48 pm
Thanks for the stream...
Indeed, the audio is NOT compliant : STD BUFFER which is 3584 Bytes has a BUFFER OVERFLOW with a meaning value of 4700 Bytes in the buffer, which is surely due of porblem with PTS and arrival time in the multiplexer.
Charles has to reduce a little the arrival time in order to be compliant.
Maybe I could look in the code, but not sure that actual version is on github (Charles, let me know).
73's Evariste F5OEO
on7ma
Post by on7ma » Thu May 12, 2016 1:54 pm
Tnx Evariste
Good news... !
If any change is made, I'll test it and put feedback
JP
Post by G4GUO » Thu May 12, 2016 2:35 pm
Evariste I assume you are talking about receive buffer?
On transmit I am delaying the PTS by an arbitrary 200 ms. I could reduce that slightly.
If I reduce it too much the video will go funny.
I will probably post a new release at the weekend. I have been adding support for band switching
to the FPGA code today and I don't want to release anything until that is done.
If anyone is interested I recorded a TS file from the local BBC DVB-T multiplex.
I may use that as a reference to test against.
f5oeo
Post by f5oeo » Fri May 13, 2016 1:25 pm
Charles,
Yes I was refering to the standard receiver buffer model defined in ISO13818 norm.
A delay of 200ms is too much, and should be around 120 ms (between PTS/PCR). It should avoid to be in overrun and not too low to not reach underrun.
Could provide you some tools to analysis it if needed.
Evariste
Post by G4GUO » Fri May 13, 2016 1:50 pm
I set it to 140 ms in the release I put out yesterday.
This morning I split the definition of the video and audio delay so I can now change
them independently.
I have some software for measuring the buffer sizes but whatever I set it to the software complains.
Even when I try it on a BBC multiplex TS I recorded off air the software complains. :lol:
- C
f5oeo
Post by f5oeo » Fri May 13, 2016 2:35 pm
OK, great to have audio and video delay independent...it will be easier to tweak and correct eventual lipsync.
The tool to measure buffer size...need maybe an other (check your mailbox).
On an other subject : is ExpressServer up to date on github ? Think to include it by cloning you repositorie and compile for interfacing with rpidtav project on git.
Post by G4GUO » Fri May 13, 2016 3:13 pm
I have the files.
Yes the Express Server on Github is the latest. I have been concentrating on Windows
for the last 6 months so not much has happened on Linux along with the fact I have been
concentrating on programming the FPGA in my QuadSDR project (big learning curve).
