2MS DATV from Raspberry Pi
M0SKM
Re: 2MS DATV from Raspberry Pi
Post by M0SKM » Mon Nov 07, 2016 7:09 pm
OK tried Ctrl + a and no joy. Then Ctrl + all the other keys in sequence. :shock:
Then I pulled the plug out...that cured it.
f5oeo
Post by f5oeo » Tue Nov 08, 2016 10:29 am
Patern is launch from the console menu ? If it is the case : after transmit, just press "enter" or "esc".
If launch from rpidatvgui : have to touch the TX area (hidden by the patern)...
But maybe I miss something ?
M0SKM
Post by M0SKM » Tue Nov 08, 2016 4:46 pm
Hi Evariste
I'm using the full version of Jessie with the desktop.
Patern is as you say started from the console menu and works fine. Stopping it is the problem; there doesn't seem to be any keystroke or combination of keystrokes to cancel patern and return to the menu.
Hitting enter or escape does not work.
Arthur G4CPE has the same problem; also G8BYI commented on GB3SQ that the only way out was a disconnect.
Thanks for the great software, I think we can all wait for patern.
73 Steve
f5oeo
Post by f5oeo » Tue Nov 08, 2016 5:05 pm
Hi Steve,
I never tested it with the desktop (command line geeker !). On a console, I don't have any issue. But I have to test on a complete jessie to see what happens ! Sorry for that !
73's Evariste
f4fdw
Post by f4fdw » Sun Nov 20, 2016 6:50 pm
hi
I have seen that some use jessie not lite, I tested without success, I have the signals i and q and the output rf but no quality on my receiver, can explain me as install rpidatv under jessie , thank you
73 f4fdw Laurent
Post by G8GKQ » Mon Nov 21, 2016 6:26 pm
Hi Laurent
Which output mode are you trying to use: IQ, QPSK RF or DigiLite?
f4fdw
Post by f4fdw » Mon Nov 21, 2016 7:47 pm
hi Dave
My output is I and Q mode
73 f4fdw Laurent
Post by G8GKQ » Tue Nov 22, 2016 12:18 am
OK
Others have had that working. Sorry, more questions:
- What type of modulator are you using
- What source of video are you using.
- What version of RPi?
The more info that you provide, the more likely it is that we can solve the problem
f4fdw
Post by f4fdw » Tue Nov 22, 2016 11:45 am
_AD8346 modulator (digilite)
_raspicam
_last version of rpi
At loading it decodes and then on the way to the graphic it cuts
f4fdw
Post by G8GKQ » Wed Nov 23, 2016 9:44 pm
Hi Laurent
As discussed, I've had a look at the problems of rpidatv running on Desktop Jessie and decided that it would take too much time to solve at the moment. Everything is so much easier with Jessie Lite - please give it a try. Sorry that I can't be more help.
