2MS DATV from Raspberry Pi
f5oeo
Re: 2MS DATV from Raspberry Pi
Post by f5oeo » Thu Nov 03, 2016 2:08 pm
To be sure : remove dt-blob.bin in /boot folder
Reboot and set a SR at 250, it should be transmit at 125 KS
G4CPE
Post by G4CPE » Thu Nov 03, 2016 3:27 pm
OK dt-blob.bin removed now symbol rate is half of what ever is set, ( 250 now 125 ) resulting in a good lock with all green lights in Tutioune but no video display.
Arthur
f5oeo
Post by f5oeo » Thu Nov 03, 2016 3:54 pm
Can you record the Transport Stream with tutioune (10-20 seconds) to see what's in ?
G4CPE
Post by G4CPE » Thu Nov 03, 2016 4:36 pm
I recorded the TS in tutioune but when I try to play the file Windows says the file is un-playable.
f5oeo
Post by f5oeo » Thu Nov 03, 2016 6:50 pm
Can you upload the ts file somewhere or send by mail?
Post by g0mjw » Sat Nov 05, 2016 5:28 pm
Using the PI and Digithin, there is no audio being sent at 333ks. I assume this is intended? Makes sense given the limited bandwidth but just checking.
f5oeo
Post by f5oeo » Mon Nov 07, 2016 9:58 am
For now, audio is not included in the stream. Next step !
M0SKM
Post by M0SKM » Mon Nov 07, 2016 11:52 am
Does anyone know the secret to switching off the test pattern and returning to the menu? I've tried many keyboard combinations and now admit defeat. :(
Steve
G0NMY
Post by G0NMY » Mon Nov 07, 2016 5:44 pm
try PRESSING CTRL +a That gets used for abort.
Just a guess mind you ;-)
:D
M0SKM
Post by M0SKM » Mon Nov 07, 2016 5:54 pm
Thought I'd hit control and every other key; I'll try control a again.
Evariste has done a storming job so I'm happy to wait for the bugs to be ironed out.
Steve
