ADALM-PLUTO (new DATV SDR)
vma
Post by vma » Fri Mar 02, 2018 11:54 am
I just received my ADALM-PLUTO (after waiting 5 months...).
I put my first impressions on my blog (https://vma-satellite.blogspot.pt/2018/ ... ds-on.html), but overall, the most impressive application so far is without doubt DATV-Express! Amazing and this alone makes it worth buying this SDR.
Regards,
Vitor
G8DKC
Post by G8DKC » Sun Mar 04, 2018 9:21 pm
Hi Vitor,
Good to see you on the forum, will be running up your "VMA Simple Spectrum Analyser" software again soon.
Will have to check out your latest version...
Peter
G8PEF
Post by G8PEF » Fri Apr 20, 2018 8:54 am
Hi, folks
Is anyone using the Pluto with a Mac? What SDR software are you using?
I've tried to get GQRX talking to the Pluto, but I'm lost - GQRX installs on the Mac (OSX Lion) does't seem to recognise the Pluto is there. GQRX also won't support TX, so I'm interested in what everyone else's experiences are.
I'm also about to try getting it to work with SDRAngel on a Win 10 setup - any tips/advice before I head down the inevitable blind alley(s) would be welcome :)
John
on7ma
Post by on7ma » Sun Apr 22, 2018 12:52 pm
Problem
Just got my new ADALM-Pluto today, after 2 months waiting from Mouser
it seems the new version 0.27 firmware, and drivers 0.7 installed
All drivers seem to work, when going to 192.168.2.1 , I can see the Pluto's Webpage
even the Pluto USB drive is seen
Allthough everything is OK, I can not start DATV-Express 1.25p5, I got always error "Adalm-Pluto not found - Error 1005
Config Dump
[SDR HW] PLUTO
[SDR IP] C0A80201
[ID SERVICE] 4095
[ID STREAM] 4095
[ID NETWORK] 1
[EVENT DURATION] 60
[EVENT TITLE] "Ham Radio Now"
[EVENT TEXT] "Program about Amateur Radio"
[PID PMT] 4095
[PID PCR] 256
[PID VIDEO] 256
[PID AUDIO] 257
[PROGRAM NR] 4095
[CODEC VIDEO] h262
[CODEC VIDEO GOP] 25
[CODEC VIDEO B FRAMES] 0
[CODEC VIDEO PERFORMANCE] "superfast"
[CODEC AUDIO] mp1
[CODEC AUDIOPRESENT] true
[CODEC AUDIOBITRATE] 64000
[NAME PROVIDER] "YOUR CALL"
[NAME SERVICE] "Digital TV"
[TX MODE] DVB-S
[TX FREQ] 1249000000
[TX LEVEL] 31
[DVBS FEC] 1/2
[DVBT FEC] 1/2
[DVBT CONSTELLATION] 64QAM
[DVBT GUARD] 1/32
[DVBT CHANNEL] 2MHz
[DVBT MODE] 2K
[DVBS2 FEC] 2/3
[DVBS2 PILOTS] OFF
[DVBS2 CONSTELLATION] 8PSK
[DVBS2 ROLLOFF] 0.20
[TX SR] 2000000
[TX PORTS] 0
[CAPTURE VIDEODEVICE] "Logitech HD Pro Webcam C920"
[CAPTURE VIDEOFORMAT] "1280 720 1 RGB24"
[CAPTURE VIDEOINTERLACED] no
[CAPTURE VIDEOASPECT] 4:3
[CAPTURE AUDIODEVICE] "Microfoon (HD Pro Webcam C920)"
[TWIDDLE VBITRATE] 0.700000
[ONAIR VIDEOFORMAT] "Input Format"
[VIDEO IDENT] ON
-21
[Q DC OFFSET] -39
No matter what I do.. every time same error
Could it be due to firmware 0.7 ?
Tnx 4 help ?
ON7MA
on7ma
Post by on7ma » Sun Apr 22, 2018 2:07 pm
I forgot to mention, that I Run Windows 10 x64 - 16299.371
Could be the reason, since they use libiio.dll
on SDR# it doesnt surely work
On7MA, Jemp
on7ma
Post by on7ma » Mon Apr 23, 2018 9:11 am
Hello All
Found problem
the USB-IP address in ADALM_PLUTO config file has to be filled in, to 192.168.2.1
the config.txt file is on the USB Flash Drive that comes up when putting in the Pluto
with this settings , it works flawlessly
# Device Configuration File
# Edit, Save and then Eject the USB Drive
[NETWORK]
hostname = pluto
ipaddr = 192.168.2.1
ipaddr_host = 192.168.2.10
netmask = 255.255.255.0
[WLAN]
ssid_wlan =
pwd_wlan =
ipaddr_wlan =
[USB_ETHERNET]
ipaddr_eth = 192.168.2.1
netmask_eth = 255.255.255.0
[SYSTEM]
xo_correction =
udc_handle_suspend = 0
[ACTIONS]
diagnostic_report = 0
dfu = 0
reset = 0
calibrate = 0
Suc6 anyone
ON7MA
kd2hns
Post by kd2hns » Tue May 01, 2018 11:04 pm
Hi All
I have just got my Pluto and set it up. Was able to get DATV-Express to work no problem, great program. I can see it transmit on my rtl-sdr dongle running gqrx waterfall but no video of course. Is there any program for the rtl-sdr that will decode the video or another SDR receiver that can decode the video or maybe an old satellite receiver. I have like 4 of them laying a round? Any advise would be great, thanks.
Chuck
Post by G4GUO » Wed May 02, 2018 8:07 am
https://wiki.batc.org.uk/Lean_DVB_reciever
Yes the spelling of receiver is wrong!
kd2hns
Post by kd2hns » Fri May 04, 2018 10:24 pm
Charles
I was thinking more in the line of windows program. I did try to install leandvb on my raspberry pi 3 had some errors with my RTL-SDR so I'll try and figure that out. I bought the MiniTiouner-Express and should get it by Saturday. I'll give you a update on how that works out too. Thanks for your help.
Chuck
M5TXJ
Post by M5TXJ » Sat May 05, 2018 6:07 am
Hi all,
Has anyone investigated using both the TX and RX sides of the Pluto to produce a DATV TRX for 13cm, 9cm or 6cm?
73 Dave
