LKV373A Hackable HDMI to UDP TS MPEG4 encoder for $40
Re: LKV373A Hackable HDMI to UDP TS MPEG4 encoder for $40
Post by G4GUO » Fri Jul 07, 2017 5:17 am
Hi Bevan,
You might want to try using WireShark https://www.wireshark.org/ to look at the TS
as there is an issue with it sending zero length UDP packets which FFMPEG does not like.
f5oeo
Post by f5oeo » Mon Jul 10, 2017 2:36 pm
Play also with my lkv373A.
Transport stream output is not workable "as is" as it is not a constant bitrate. Need a process to extract video PID and reprocess entire TS (as mention by Charles).
The encoder is probably a ITE IT9919 which is used in HV320E from Hides.
No parrallel output is possible but a serial one is written in the datasheet.
Video is quiet constant so working with this module seems a good option at least with a software job for post process.
Evariste
vk5bd
Post by vk5bd » Tue Jul 11, 2017 6:23 am
I have been having a bit of a play and still needing to get on top of which firmware version is best, even in VLC at them moment I don't get a stable picture so I need to do more experimenting there.
I also used ffmpeg to replaced the pids within the rpidatv code (thinking that the process behind Vmix to RPIDATV works okay), but until I get stable video this process is not going to work either.
My current method is to receive the stream with your MNC code into a new rawvideots pipe, then ffmpeg this pipe into a mpegts setting pids etc and then piping back into videots for rpidatv's use. There is a little degradation of the stream via this method but at least the pids are manageable.
