The Win7 is running free vMix to control the video and GraphStudioNext to construct a graph with DirectShow filters that are configured into this graph to add the software MPEG2 encoding filters from MainConcepts (grabbed them off my Hauppauge CD-ROM). Finally, a small software program (also another filter) called MajorUPDsender runs on the Win7 notebook and sends the UDP packets via Wi-Fi to the IP address of my ODROID.
vMix manages the C920 video and GraphStudioNext allows MPEG2 encoding and aims the UDP packets to the Wi-Fi port
The ODROID U3 is running an express_server that captures the incoming Wi-Fi UDP packets that are sent by the ODROID to the DATV-Express board. The express_server code was written by G4GUO and needed to be compiled from source onto the ODROID. Note the normal DATV-Express GUI software is not be used at this point.
The express_server software is installed and runs on ODROID. It captures the incoming Wi-Fi UDP packets and sends the Transport Stream to DATV-Express board
The DVB-S Standard Definition (SD) video was then displayed on my SatLink analyzer. The best part may be that there is no Hauppauge video-capture module involved with this testing set-up.
Still a lot of work that I need to do in order to clean up the somewhat-jerky video and some latency issues. But it works and it is fun.
73…de Ken W6HHC
