Help needed - Technisat skystat 2 pc card setup.
g0uoz
Post by g0uoz » Fri Nov 08, 2013 5:45 pm
Hi, could anyone tell me the software setup for the skystat 2 pc card?
What settings do i need for the scan page, I have had no problems with the standalone digital receivers - frq and symb rate etc.
Any help please ? .. screen grab would be awesome.
Many thanks G0UOZ.. Tony.
Re: Help needed - Technisat skystat 2 pc card setup.
Post by M0DTS » Fri Nov 15, 2013 2:48 pm
Hi Tony,
It's a Long time since i used my Skystar2 card but should be easy enough to setup..
The LNB setting are in the satellite setup if i remember correctly, you should be able to set it to 10GHz, careful with the number of zeros in the software as they often work in Hz...
You probably have to create a transponder with the frequency and symbol rate, then on the scan page select that transponder then press scan/search... a bit fiddley for fast frequency changes!
This will all be software dependant!
DVBDream used to be about the best sat software if i remember correctly.
Good luck..
