SDR Television
g3uis
Re: SDR Television
Post by g3uis » Sun Apr 27, 2025 3:08 pm
Thanks, guess I had several settings wrong, as at sometime I defiantly had the beacon on SR1500.
Still it works, my MER about 1/2 dBs down on my Minituner or Winterhill
Thanks again
Tony
Working
Working
G8KOE
Re: SDR Television
Post by G8KOE » Mon Apr 28, 2025 9:47 am
Sunday WW NET
I decided to run the net using SDR Television.
Using my 1.1M dish 2/3 signals OK 3/4 signals borderline.
A quick test today on my signal 2/3 H265
Picotuner Mer 7.3
SDR Television Mer 6.5
Beacon Test
Picotuner MER 8.9
SDR Television MER 8.4
I have noticed H264 signals comparison are close or sometimes SDR Television are higher.
Overall what an excellent program will be using it for the next WW NET.
Thanks for all who joined the Sunday WW NET.
I will try and encourage FEC 2/3 to help my 1.1M dish.
73's
Martin
G8KOE
VK3IE
Re: SDR Television
Post by VK3IE » Mon Apr 28, 2025 11:03 pm
Just to keep it all real,
And where we all started I guess, In this world of Digital
A blast from the past.
As received at my station VK3IE yesterday for VK3YLH
444 MHZ AM ATV Simplex, 55k approx
Cheers
Robert
vk3ie
Pa3fbx
Re: SDR Television
Post by Pa3fbx » Tue Apr 29, 2025 5:22 pm
Double Side band for Sure...
Here in Europe AM -TV on 70cms is discouraged for years. 70cm band is only 10Mhz wide and with all satellite, Dstar, DMR , and even simple 433 controllers you get lots of bad eye and angry words..
Local ham had blocked several car's here at the local government building so the White collars could not go home...
He had only 100 Watt AM TV on 434Mhz... :D
So we keep using RB TV only to keep everyone happy.
And i had last week a SDR-TV signal over 80K with 10 watt on 70cm..
B5 signals with HD quality..
Benno
g8lce
Re: SDR Television
Post by g8lce » Mon Jun 30, 2025 12:45 pm
SDR Television beta 3 allows terrestrial working. I tried it with a pluto via USB and also via a good USB extender and was very impressed. Using a 2Mhz bandwidth in the Pluto setup configuration and a 333ksr it gave very good results. I used vMix to feed it ( via external output ) and sent my usual HD test videos. I had problems when it came to sending to a networked pluto but that might be my problem. The computer has a 4060 graphics card and sent H265. Using my laptop it was a problem due to it not supplying enough current on its USB. I will look at that again sometime.
A new beta version is coming soon.
Thank you Simon.
DL5BCA
Re: SDR Television
Post by DL5BCA » Fri Jul 04, 2025 7:53 am
SDR-TV Beta #4 has been released: https://www.sdr-radio.com/sdr-television-beta-4
73 Thomas DL5BCA
I always have crazy ideas.
Please don't be surprised.
PA3CRX
Re: SDR Television
Post by PA3CRX » Thu Jul 10, 2025 9:51 am
I wonder about the timeframe for the apparent discouragement of 70 cm AM-TV in Europe.
In the Netherlands, I've given several well-attended lectures on ATV, where promotion of AM on 70 cm was included. Not on 434.250 across the entire band, but with reduced bandwidt, with a simple video filter. I wrote an article about this in a Dutch amateur magazine (Electron, April 2014), which also appeared in a slightly revised version in CQ-TV 269.
At a lecture by Rob PE1ITR, I asked him about his experiences with D-ATV and (analogue) RB-ATV in the 70 cm band. He found that with very little lift, aircraft scatter, or whatever, RB-ATV could display the picture very briefly. With D-ATV, that's too short to lock.
OK, that's/was about the Netherlands.
In other European countries, ATV isn't promoted much anyway, not seen discouraged on 70 cm. At least, if I'm basing my findings on publications from the various clubs.
I think the last time ATV was subject at the IARU was in 2019, with my presentation on its status in the Netherlands (https://youtu.be/bunq3W_Cdig).
I think RB-ATV in the 70 cm band is a very simple, accessible way to get new ATV users excited.
And maybe I'm wrong and missed the discouragement in Europe :D
