Longmynd Client HELP
F1SSF
Re: Longmynd Client HELP
Post by F1SSF » Fri Nov 22, 2024 4:37 pm
Hi alls
I have installed longmynd server on RPI + Minitioun, it run and stream .
I can read TS flux with vlc.
But impossible to read fllux with the longmynd client. I don't understand why?
Thank you for support.
73 F1SSF franck
server and flux.png (269.96 KiB) Viewed 6469 times
Pa3fbx
Post by Pa3fbx » Sat Nov 23, 2024 12:29 pm
Hi Frank,
I had to go back and look for my setup.
client settings.jpg (77.56 KiB) Viewed 6373 times
client settings2.jpg (90.6 KiB) Viewed 6371 times
This works for me.
Raspberry is at x.x.x.49
and i configured a mukticast 230.0.0.12
Hope it helps..
Benno
F1SSF
Post by F1SSF » Sat Nov 23, 2024 6:55 pm
Hi Benno
Thank you for your message.
Same setup that you, impossible to displaying in longmynd client screen, only on VLC.
:cry: :cry:
I don't think it's a firewall problem, because port 4003 is open (VLC read TS on 4003) , and longmynd too since it shows me the BATC spectrum
See debug windows ans statut packets
G1BVI
Post by G1BVI » Sun Jun 15, 2025 7:49 pm
Hi Tom
I too have upgraded to a Win 11 machine and am struggling with longmynd.
This is my dEBUG .
0:36 : Snapshot Path is : C:\sat pics\
20:36 : Longmynd Host: 192.168.178.121
20:36 : Longmynd TS: 4003
20:36 : Longmynd UDP: 8080
20:36 : VLC Hardware Decoding: True
20:36 : Multicast Connection: True
20:36 : Multicast Host: 230.0.0.12
20:36 : Autotune Avoid Beacon: False
20:36 : Snapshot Wait (Secs): 5
20:36 : Autotune Wait (Secs): 30
20:36 : Get Local IP:
20:36 : 192.168.178.121
20:36 : Error: Control WS Closed - Check WS IP
20:36 : Attempting to reconnect...
20:36 : Error: Monitor WS Closed - Check WS IP
20:37 : Error: Control WS Closed - Check WS IP
20:37 : Attempting to reconnect...
20:37 : Error: Monitor WS Closed - Chec
I switched OFF the win 11 firewall .
My setting screen is as you detailed..
Yet it will not connect?
WB chat all works so maybe the Longmynd sd card needs a rebuild??
Any advice would be greatly appreciated
Nick
Screenshot 2025-06-15 204515.png (186.77 KiB) Viewed 4351 times
G1BVI
Post by G1BVI » Sun Jun 15, 2025 7:50 pm
Forgot to add
I CANNOT open http:/192.168.178.110:8080 either
Nick
G1BVI
Post by G1BVI » Sun Jun 15, 2025 9:06 pm
Tom I solved it but !!
My Pi is 192.... 110
The Host PC running the client is 192.......121
In the settings config I have to put 110 (the pi) as the Host and 121 in the Configure Longmynd IP??
Dont understand but it works..
Next to adjust my dish
Nick
