DATV Easy 2.17 First duplex DATV codec H266 VVC
F1EJP
Post by F1EJP » Thu Apr 13, 2023 9:48 am
Yesterday a first:
First QSO Duplex DAVT on QO100 between F1EJP and ON1RC in H266 VVC encoding with DATV-Easy 2.17 Beta
73 Dominique F1EJP
MYCALL_12_04_2023_23h40_10.zip
(995.87 KiB) Downloaded 654 times
Basil
Re: DATV Easy 2.17 First duplex DATV codec H266 VVC
Post by Basil » Thu Apr 13, 2023 10:03 pm
Thanks for continually pushing the boundaries for and with us all.
It would be good, in my humble opinion, if someone could do a brief write up of how this new compression will affect DATV enthusiasts and what we will need to consider for its reception and transmission.
I believe currently there's no out of the packet solution to receive H266, short of us doing our own coding, or code modifications? That would be a step too far for me, so a Dummy's Guide of where this may go would help me, and maybe others, greatly.
Again thank you Dominique.
Chris 2E0ILY
Best regards,
F1EJP
Post by F1EJP » Fri Apr 14, 2023 11:40 pm
Hello
This new compression will reduce the video stream by 50% for the same quality and therefore the bandwidth occupied.
It is a future compression standard for 4K 8K television.
The first televisions equipped with a decoding chip should be released this year !
For the moment the H266 (VVC codec) only works in soft coding because there is not yet a graphic card which supports it.
CPU load goes from 60 to 100%
for the moment it is necessary to limit to a small flow and fps
The latency is about 15 seconds.
If you want to test in reception and give a report download the files below. You must unzip the folder on the desktop and if necessary modify the ip and the port in the .bat file to correspond to the udp output of the Minitiouner
and launch the .bat corresponding to the desired definition.
http://www.vivadatv.org/viewtopic.php?f=84&t=1002
73 Dominique F1EJP
Basil
Post by Basil » Sat Apr 15, 2023 8:08 am
Wonderful, that's something I will definitely try this weekend, thanks Dominique.
Best regards,
M0DQW
Post by M0DQW » Sat Apr 15, 2023 10:54 pm
I also captured today, quality looked really good!
Although I used DVB GUI with the pluto, but its a pain in rear end for tuning :-) Will try MT next time.
Basil
Post by Basil » Sun Apr 16, 2023 10:19 am
Decodes are not very CPU intensive at all, and the results from low rates were excellent, I'm looking forward to Easy 2.17 to see how intensive Tx is, and how my PC copes. Thanks Dominique and beta testers!
Best regards,
G7JTT
Post by G7JTT » Wed Apr 19, 2023 10:43 am
I've found a version of MPV (similar to VLC) which has H266 support built in, it can be found here
https://github.com/MartinEesmaa/VVCEasy ... ag/v.1.0.1
To use create a shortcut on the desktop then edit the properties and add udp://:@192.168.1.105:4003 (edit with your IP) to the end of the target line so you end up with something like
C:\MPV.NET-VVCEasy-Windows-x64\mpvnet-vvceasy.exe udp://:@192.168.1.105:4003
73 John G7JTT
