FreeStreamCoder Software to Generate Mpeg-TS Streams >> New V2.80
g4saq
Re: FreeStreamCoder Software to Generate Mpeg-TS Streams >> New V2.78
Post by g4saq » Thu Nov 25, 2021 2:46 pm
Hi Mike,
I just checked again. Now seems to be fairly consant at 20% with test card and with me waving at the screen. Other station transmissions seem to be between 3 and 12%. Perhaps this is something to discuss on the net tonight. 73 Russ.
Post by g0mjw » Thu Nov 25, 2021 6:16 pm
Russ,
The general software is conservative. The way to get a low null rate is to push the envelope using a script. 20% is fine, really. Stop worrying about it.
F1EJP
Re: FreeStreamCoder Software to Generate Mpeg-TS Streams >> New V2.79
Post by F1EJP » Tue Nov 30, 2021 11:42 pm
Small fixes:
- freestreamcoder opens faster.
- buffer optimization
http://www.vivadatv.org//viewtopic.php? ... 6&start=10
73 Dominique F1EJP
g8ayc
Post by g8ayc » Sun Jan 09, 2022 8:21 pm
Would it be possible to have a manually set image size saved in the ini file rather than have it derived from the symbol rate?
73 Nigel G8AYC
Pa3fbx
Post by Pa3fbx » Mon Jan 10, 2022 10:25 pm
The whole point is making the setting simple...
You can change settings after selection but the advised settings are preset so you do not need to think...
If you start changing ini files you may end up creating an ffmpeg scripting witch you can change to your optimum.. But this is not simple..
Benno
F1EJP
Re: FreeStreamCoder Software to Generate Mpeg-TS Streams >> New V2.80
Post by F1EJP » Thu Feb 03, 2022 11:43 pm
New improvement and adding codec audio after new developpement DATV-EASY avaible very soon
V2.80
73 Dominique F1EJP
PE5PVB
Post by PE5PVB » Fri Feb 04, 2022 9:31 am
Do you support AAC-HE audio?
ON4AAH
Post by ON4AAH » Wed Feb 09, 2022 3:49 pm
Thanks Dominique, with the latest software version we can use now the lime SDR mini or the Adalm pluto to work on our local repeaters that still work in DVB-S and AC3.
We have now the same capabilities as an S-R systems D-ATV transmitter. 73's ON4AAH Albert ;)
F1EJP
Post by F1EJP » Wed Feb 09, 2022 10:29 pm
Thanks you all for your feedback !
In the future may be a version with the ACC HE codec if I find a version of ffmpeg with this codec that works correctly for a bitrate greater than 2Ms
For now this codec will be available in the new DATV-Easy software. ;)
Dominique F1EJP
G7JTT
Post by G7JTT » Wed Feb 23, 2022 9:36 am
Hi all just had Microsoft delete FreeStreamerCoder V2.80 saying its detected Win32/contebrew.A!ml, seems no way to put it on a safe list any ideas ?
Screenshot 2022-02-23 083902.jpg (33.14 KiB) Viewed 7690 times
73 John
