DATV-Easy V2.00 >> Download V1.25
F1EJP
Post by F1EJP » Thu Nov 18, 2021 11:44 pm
I started a new development > Datv-Easy for >> Windows :D
>> first for the LimeSDR mini
I await your comments or suggestions!
First tests in progress.
73 Dominique F1EJP
G4FKK
Re: DATV-Easy V1.0
Post by G4FKK » Fri Nov 19, 2021 12:10 am
That looks as if it should be very interesting Dominique! At the moment I'm using OBS -> FreeStreamCoder -> Portsdown4 -> Lime Mini which works very well. It would be nice though to be able to free up the Portsdown for receive while TX'ing sometimes.
Good luck and 73,
Martin.
F1EJP
Re: New soft DATV-Easy V1.0
Post by F1EJP » Tue Nov 30, 2021 11:46 pm
new Screen
In test on QO-100
73 Dominique F1EJP
vu3obr
Post by vu3obr » Wed Dec 01, 2021 2:50 am
Thank you for the development Dominique F1EJP.
At the moment I'm using OBS -> FreeStreamCoder -> Portsdown4 -> LimeSDR USB which works very well.
Lime Mini settings can support LimeSDR USB to? if not please add LimeSDR USB on the selection menu.
Waiting for your new DATV_Easy V1 software for test.
Saro
VU3OBR
Post by g0mjw » Wed Dec 01, 2021 9:15 am
Interesting. How is the PTT managed? At the moment that is done via my Portsdown terrestrially or Pluto on QO100. It would be useful if we could control with a USB relay or similar. This would account for the Lime calibration spike as well and could even sequence a pre-amp so that it is switched out before the RF. Like many, I have a power through the cable SSB electronics pre-amps for 2m, 70cm and 23cm. My IC9700 can power these, it would be useful if the DATV system could do the same.
vu3obr
Post by vu3obr » Wed Dec 01, 2021 11:26 pm
Received the test transmission :o
Valid point Mike, USB relay must be added.
Saro VU3OBR
F1EJP
Post by F1EJP » Thu Dec 30, 2021 12:23 am
Currently version 1.15 being tested on QO100 regularly
Operational from SR 25Ks to 1Ms in DVB-S2
> Still to be tested with an OM equipped with DVB-T reception of 125 khz at 1M
> Still to be tested by an OM on Pluto because I don't have one.
(the driver for the LimeSRD mini or Pluto must be installed on the pc)
This software will not be able to compete with the Portsdown or the Pluto with the software of Evariste and perhaps not with the DATV Express!
It is based on FFMPEG and GNURADIO modules, all adapted and configured under Windows.
I spent a lot of hours trying to get the best result.
It will allow you to have fun at a lower cost since only the PC with the OBS or Vmix software and the SDR module are necessary.
You need a pc with an I5 processor and if possible I7 either recent or with an NVIDIA card
I will soon put the file on VIVADATV forum for testing.
73 Dominique F1EJP
F1EJP
Post by F1EJP » Tue Jan 04, 2022 11:47 am
>> I'm looking for a version of ffmpeg 4.3.1 compiled with the libfdk_aac enable library ;)
Indeed the results obtained are clearly better with this version than the last 4.4 which causes discontinuities for a flow greater than or equal to 1M
In addition with the aac he codec we still save bandwidth
My Windows build attempts haven't worked so far.
The software is almost ready for first release.
Thanks in advance if you have this version with lifdk enable send me a message.
73 Dominique F1EJP
G7JTT
Post by G7JTT » Wed Jan 05, 2022 9:13 pm
Bonjour Dominique,
Is this of any use ?
https://gist.github.com/aslushnikov/422 ... be04f2e5ac
Happy New Year 73 John G7JTT
F1EJP
Post by F1EJP » Fri Jan 07, 2022 12:08 am
Hello John,
Thanks for the reply, I have tried different ffmpeg compilation solutions !
I am not a specialist in this programming and in this solution which allows to choose the version I do not know all the commands,
It's very difficult..
I keep looking.
73 Dominique F1EJP
