DATV Reception with SDRangel
M0SKM
Post by M0SKM » Fri Jan 11, 2019 4:36 pm
Following the link on BATC facebook I've had success receiving my DATV signal through SDRangel. Real pleased that I found a use for my RTL Dongle.
Steve
Re: DATV Reception with SDRangel
Post by g8gtz » Fri Jan 11, 2019 4:44 pm
Hi Steve,
Looks good - can you repost the link as not everyone is prepared to use Facebook - I only do it very reluctantly for a variety of reasons!
BTW - do we know if they have implemented Veterbi decoding - if so that makes it better than LeanDVB.
M0SKM
Post by M0SKM » Fri Jan 11, 2019 5:14 pm
OK Noel here are some long links.
You need this download of SDRangel as it includes the DATV plugin.
https://github.com/f4exb/sdrangel/relea ... PH1Pf1wQTU
Here is the instruction video posted on YouTube by Corrosive. LOL
https://www.youtube.com/watch?v=Bb8S_J9 ... 4O0wPQCQSE
Below the video there is a batch file needed to set the path to ffmpeg. Note the path is C:/ffmpeg not the standard C:/ffmpeg/bin
The plugin does have Viterbi but it warns that it's processor hungry.
Steve
G0NMY
Post by G0NMY » Fri Jan 11, 2019 9:23 pm
I had an issue with Corrosives batch file in that it did not seem to add c:\ffmpeg to the path.
Having just looked at the setx command I think it sets it in the registry which may then involve a system reboot.
Instead I just used the following command in a Dos/cmd window
set path=c:\ffmpeg;%PATH%
This puts it at the beginning of the path table.
Oh im using Win7 64bit.
Hope that helps
http://www.g0nmy.blogspot.co.uk/
¡ʎɐqƎ ɟɟo pɹɐoqʎǝʞ ɐ ʎnq I ǝɯᴉʇ ʇsɐl ǝɥʇ sᴉ sᴉɥʇ
Post by g0mjw » Sat Jan 12, 2019 8:42 am
Hi Steve,
I think someone re-posted one of my tweets about this as well as I just found it on Facebook. I was using this some time ago under Linux (e.g. https://mobile.twitter.com/TheRealMike/ ... 4192287744 ) but the significant difference now is that it works in the Windows distribution and seems to work much better. There are problems with the Gui for those of us with 4K displays but otherwise it's at last viable to do this sort of thing with Windows.
g8vpg
Post by g8vpg » Sat Jan 12, 2019 10:17 am
I did a cursory search for software that might work with the Lime SDR Mini. SDR Angel came up. Would this work with the receive port of the Lime? That would be really neat - digital TV receive up to 3.5GHz!
73 Shaun.
M0SKM
Post by M0SKM » Sat Jan 12, 2019 1:34 pm
Yes it works OK Shaun; tried it last night.
Steve
M5TXJ
Post by M5TXJ » Tue Jan 15, 2019 3:51 pm
I have this working with my Pluto, I didn't have to run the batch file as ffmpeg was already installed for VMix.
73 Dave.
kr0siv
Post by kr0siv » Mon Jan 21, 2019 8:15 pm
I've recently uploaded a video explaining how to do this with the RTL-SDR and SDRAngel under windows. https://www.youtube.com/watch?v=Bb8S_J9peD8
