iViewHD dongle
iViewHD dongle
Post by radiogareth » Tue Sep 18, 2018 6:34 pm
A week or so ago I read an article that suggested using one of these iViewHD dongles as nice portable monitors for DATV with an android phone or tablet. But I can't find the reference to it now (age), maybe it was on twitter which I only occasionally visit.
It certainly works well as a sensitive freeview terrestrial tuner on my PC, using the supplied software, offering a record option too. But not what I need really. If it would oblige on 437 or 1296 that would be handy.
Suggestions welcome.....
on4bhm
Re: iViewHD dongle
Post by on4bhm » Sat Oct 13, 2018 8:01 pm
We are using these dongles to rx the new datv dvbt2 transmitter of on0snw.
the transmitter is still in test and will be located on a 83m high mast in several weeks.
We are using standard 8mhz dvbt2 on 1290Mhz
With vlc or dvbviewer you can tune the iview dongle to 23cm band without the need of a down (uhf channel) down converter.
the iview dongles can be found on ebay.
there are even more cheaper dongles that work also.
73's
on4bhm
sysop on0snw
Re: iViewHD dongle
Post by radiogareth » Sun Oct 14, 2018 7:02 am
Many thanks for the pointers, I'll give it a try.
It seems to find the dongle with VLC media player and also demo version of DVB viewer.
Not sure how to set rx freq to 1290 in either though. I have a Pluto working with Express DVB so can produce signals within existing European DATV (into a dummy load).
Any basic guidance or pointers welcome.
As you are using the \Iview on your repeater, are they 'better' than the 802-T2 dongles?
on4bhm
Re: iViewHD dongle
Post by on4bhm » Sun Oct 14, 2018 12:48 pm
in dvbviewer there is a "transponder list"
it is a txt file.
you can adjust the content. and change for instance 868mhz to 1280 or so.
dvbviewer demo will scan that channel. the iview dongle will tune to what freq dvbviewer tells him to....
with vlc you can just enter the freq.
you van even use iview dongle with tablet and smartphone
you just need the correct otg cable.
than you would be really portable !!
on4bhm
Re: iViewHD dongle
Post by on4bhm » Sun Oct 14, 2018 12:50 pm
the first time i used dvbviewer, i started transmitting on an uhf channel.
did the uhf scan in dvbviewer. detect your channel.
than change your tx freq. and adjust the freq of the channel previous found.
that was before i discovered the "transponder list"
Re: iViewHD dongle
Post by radiogareth » Sun Oct 14, 2018 1:19 pm
Great, Thanks VERY much :-)
FRANCOIS F1CHF
Re: iViewHD dongle
Post by FRANCOIS F1CHF » Sun Oct 14, 2018 1:43 pm
did you remember the ITEM nunber ?
thanks
F1CHF near Paris France
Re: iViewHD dongle
Post by radiogareth » Sun Oct 14, 2018 4:03 pm
I bought mine from Amazon as I had a gift card.
https://www.amazon.co.uk/HD-Freeview-Re ... 83HNW566Z3#
It came with a powered aerial too (not much use to us but fine for testing and works very well on DVB-T (Freeview in UK).
Re: iViewHD dongle
Post by radiogareth » Sun Oct 14, 2018 5:01 pm
Well I have it (DVBviewer) scanning and receiving plenty of UK DVB-T but its not finding my 'extra channel'. I need to read up on what I'm expecting it to receive and therefore what I should be transmitting from the Pluto. So many standards and resolutions :-)
And I have to work away for a week so i will have to leave it.
Is it worth buying the pro version I wonder? I would want it on my tablet and my desktop. Maybe I can have two installations if I only use one at a time....
