Building a DATV repeater
N6GKJ
Post by N6GKJ » Wed Jan 06, 2016 10:44 pm
Hi Guys!
Happy New Year to all!
Ok here goes, has anyone been playing with taking a transport stream directly from a receiver and dumping that through Mini Module FT2232H to a computer then onto a digilite or datvexpress?
Just some crazy thoughts I have..
Maybe a MiniTiouner output?
73,
Ron....
N6GKJ CM98ic
F6DZP
Re: Building a DATV repeater
Post by F6DZP » Thu Jan 07, 2016 4:39 pm
If you use Minitioune with a Minitiouner or Tutioune witha TT S2-1600 or TTS2-3200, you have just to press the UDP button in the software and you can use your Digilite or DATVexpress set in the UDP mode.
The TS is directly sent from the receiver to the modulator.
It is not a crazy thought, when my Digilite has been able to work in UDP mode I have used the UDP button in Tutioune to do that.
I have describe how to do that in April 2012.
http://www.batc.org.uk/forum/viewtopic.php?f=71&t=1136
Jean-Pierre F6DZP
