Terrestrial Use
M1ASR
Terrestrial Use
Post by M1ASR » Sun May 26, 2024 5:18 pm
I have built a new minitiouner with a Pico tuner modification and all works fine, just an initial issue with drivers. However, I would like to use it for terrestrial use if possible and wondered if there is any documentation around to do this? Or is it a question of changing the offsets? Thanks in advance.
73,
Graham M1ASR
Pa3fbx
Re: Terrestrial Use
Post by Pa3fbx » Mon May 27, 2024 5:52 am
I am using it fine with Open tuner on our local repeater and other terrestrial transmitions.
You can click on the LO freq to select 0 and on the RX freq to select the local freq.
Best regards
Benno
M1ASR
Re: Terrestrial Use
Post by M1ASR » Mon May 27, 2024 9:04 am
Hi Benno,
Thank you for the reply, the bottom of the screen,where the settings are, is obscured by the task bar on my laptop, so will look at why it isn’t auto hiding. Being able to look at both transport streams is great, especially on the satellite.
73, Graham M1ASR
