pi pico opentuner v09 and OA
Re: pi pico opentuner v09 and OA
Hi Colin,
My mistake two wires crossed on j1 of pico pcb, both channels working.
Than you for your input to this project.
- 20240313_143547.jpg (1.17 MiB) Viewed 11959 times
Sorry, i got to this late. Glad you got it sorted Brian. 9/10 issues so far has always been related to wiring, especially if its connecting.
Colin,
Thanks for all the help, sorted 2nd channel wires crossed on j1 pico pcb.
Hi Colin,
All working now, thanks
Hi Colin,
How do I get the python script to send the necessary bootsel command.
I had a similar problem, actually worse as the second TS crashed. Here's how I resolved it:
1. Make sure in OT you have both windows on seperate connectors Top-A Bottom-B (the second option)
2. Delete both device drivers (in control panel) and re-install them and double-check they have different addresses when you re-install. It seems that the driver install is not 100%.
Justin.
Justin.
