Cariboulite with Dragon OS
Discussions about using the CaribouLite Hat for ATV and Microwave
g8lce
Post by g8lce » Sat Jul 20, 2024 8:11 am
Just incase you have not seen it, there is this video that shows that the Cariboulite may still have some life in it!
https://www.youtube.com/watch?v=oa9ZlwYyCxA
Martin G8LCE
HB9DUG
Re: Cariboulite with Dragon OS
Post by HB9DUG » Mon Aug 19, 2024 5:32 pm
Thanks Martin !
I missed that video from the developper of Dragon OS.
I followed his video step by step and miraculously cariboulite was recognized by SoapySDRUtil without using sudo!
I have successfully tested Cariboulite on a PI4 in reception (S1G, HiF) with:
- SDR++
- SDRangel
- GNURadio
- CubicSDR
But no success with SDRangel and GNURadio on transmit.
With GNURadio using Soapy , I can see that the configuration is done correctly, but no LED TX on and no HF... :-(
Michel HB9DUG
Add on August 20
I have just compiled the gr-caribouLite block and only a source block is available...
To compile:
cd cariboulite/software/gr-caribouLite
mkdir build && cd build
cmake ..
make -j4
sudo make install
sudo ldconfig
You should see a block called "CaribouLite Source" under a section called CaribouLite
Return to “CaribouLite RPi Hat”
