G'Day from Downunder,
Was wondering whether anyone has a copy of the PCB pattern and the parts placement list for the 70cm downconverter that appears in the BATC Intro to ATV book. As the book says - as it's been described in detail previously, the pattern and parts have not been reproduced here.
Want it to do some 70cm VSB experiments. I know it's out of date but wanting to pair it up with a 70cm VSB ATV transmitter/sound carrier board that i have.
Cheers,
Chris VK3TUB
Intro to ATV Book - 70cm Down Converter PCB Pattern & Parts Placement
Adverts will be archived when the poster indicates that the item is found or after one year. If you wish to keep advertising after one year, please re-post.
VK3TUB
G7JTT
Re: Intro to ATV Book - 70cm Down Converter PCB Pattern & Parts Placement
Hi Chris if your just wanting to play, then you can always use an SDR with SDRangle, TVsharp or uAVD.
73 John G7JTT
73 John G7JTT
