Multiple LNB switcher
If you are looking for something, ask here
Adverts will be archived when the poster indicates that the item is found or after one year. If you wish to keep advertising after one year, please re-post.
G4GHD
Post by G4GHD » Wed Apr 09, 2025 9:53 am
To switch two (or more) LNBs between a single receiver. These used to be plentiful in the past, but all I can see for sale now are splitters.
There are of course RF switching boards around, but I assume those can't handle the LNB current needs.
Pa3fbx
Re: Multiple LNB switcher
Post by Pa3fbx » Wed Apr 09, 2025 10:22 am
I might not understand the big Q. but what do you want to switch..
1 LNB needs 2 different Bias voltages (12 and 18 Volt normally) and 1 LNB can feed 30 meter reasonable coax or 4 receivers on a short cable and a coax splitter (only 750 Mhz is not zo bad for the regular splitters).
You might want more and use a reasonable TV coax amplifier.. But switching is not needed for LNB. I use a dual LNB witch has 2 outputs.. 1 is powered with 12 volt and the other is 18Volt. so i have narrow and use a splitter to connect that to 1 pluto, and a sdr receiver.
other is wideband and i connect that to an 10 port amplifier and have connected several receivers, winterhill, pico, minitiouner etc...
Benno
Post by g0mjw » Wed Apr 09, 2025 11:06 am
Why not use a coax switch or relay? E.g. the SMA relays often seen at rallies? I doubt the 75 vs 50 ohm will matter much.
G4GHD
Post by G4GHD » Wed Apr 09, 2025 6:11 pm
To Benno, I want to switch between two LNBs on different dishes, to feed into a satellite rx.
Mike, I'd rather avoid that if I can, I do have two high quality RF relays, but I'd prefer to be using those for TX/RX. I'll have to use a relay though, if there's no alternative.
Post by g0mjw » Wed Apr 09, 2025 6:23 pm
You could use bias-Ts and switch the LNB supplies, then just combine the two LNBs in a resistive combiner. No coax relay needed, just two DC blocks, which you could build in to the combiner.
PE1BR
Post by PE1BR » Sat Apr 12, 2025 3:31 pm
I assume you mean a diseq switch.
If your receiver supports disec that is the easy option and you can find them cheap everywhere.
G4GHD
Post by G4GHD » Sat Apr 12, 2025 4:39 pm
Thanks, but no, it needs to be a manually operated switch. Another option I guess would be to use a separate DiSEqC generator, to effectively act as a manual switch, but they're quite pricey. If anyone knows of a DIY project, please let me know.
dc1op
Post by dc1op » Sat Apr 12, 2025 10:07 pm
probably I could be of assistance: Have a design for a Diseqc generator 1/4 using a PIC.
For more info please contact via PM
dc1op, Hub
Post by g0mjw » Sun Apr 13, 2025 7:16 am
Seems a lot of effort. Just take it apart and wire a switch in place of the microcontroller inside. The internet came up with this after searchingg for "diseqc switch schematic"
https://goughlui.com/2015/02/21/teardow ... -wsd-2041/
and this forum where someone has hacked one to do exactly what you wanted
https://empegbbs.com/ubbthreads.php/top ... nswitch_v3.
So it looks like these are simply PIN switches controlled by the micro, which may also by switching the LNB supplies. It would be easy to build one, but not worth it as you can buy one on Amazon for £5.
Post by g0mjw » Sun Apr 13, 2025 7:21 am
Just to note, the Picotuner, with the LNB supply fitted, should be able to generate the 22kHz tone commands, given the right software.
Return to “Wanted”
