Portsdown 4
Wurlytech+
Portsdown 4
Post by Wurlytech+ » Wed Jul 07, 2021 4:44 pm
Thanks to Noel - G8GTZ - my earlier request for a 4 way RF switch no longer applies.
However, having completed the Portsdown 4 and built a PA system - initially for 2m and 70cms - (using Mitsubishi 'blocks'), I need to make lp filters for both bands.
I'd be grateful if anyone could point me in the right direction - either ready built units, or circuit details so I can build them myself.
Re: Portsdown 4
Post by radiogareth » Thu Jul 08, 2021 6:26 am
Re: Portsdown 4
Post by g0mjw » Thu Jul 08, 2021 7:56 am
Also worth checking the Dutch RF shop https://dutchrfshop.nl/en/ for example https://dutchrfshop.nl/en/239-2-meter-band
...and AliExpress / Ebay if you only need a low power filter e.g. https://www.ebay.co.uk/itm/193779518114 ... SwJF1fyfrM
The cheap filters will not handle high power but you can only get 5W or so out of a 30W Mitsubishi block before the shoulders become unacceptable.
Searching for RF low pass filter tends to produce useful results.
