Minutes and chairman's report
Posted: Fri Aug 12, 2022 10:07 am
The draft minutes for the BATC general meeting held at CAT22 part1 can be found here: https://batc.org.uk/club-info/meeting-minutes/
The chairman's report can be found here: https://wiki.batc.org.uk/CAT_22_part_1
Martin G4FKK was unanimously voted to join the committee.
Immediately after the GM we held a committee meeting to comply with the constitution:
As a result, the following appointments were proposed and agreed unanimously by the committee.
Martin Charman will be chair of BATC with immediate effect and David Crump will be treasurer.
As mentioned at the GM we do intend to discuss publishing committee meeting minutes and if agreed the full minutes of the meeting will be published.
Noel Matthews
BATC secretary.
At the meeting David Crump stated that he wished to step down as chair, Brian Summers stated that he wished to step down as treasurer and Noel Matthews confirmed he was happy to serve another term as secretary.After the G.M. is over, the new Committee shall select from its number a Chairman, Secretary and Treasurer, together with additional Committee posts as required.
Noel Matthews
BATC secretary.
