Minutes and chairman's report
Information about Part 2 of CAT 22 - the online event
Post by g8gtz » Fri Aug 12, 2022 10:07 am
The draft minutes for the BATC general meeting held at CAT22 part1 can be found here: https://batc.org.uk/club-info/meeting-minutes/
The chairman's report can be found here: https://wiki.batc.org.uk/CAT_22_part_1
Martin G4FKK was unanimously voted to join the committee.
Immediately after the GM we held a committee meeting to comply with the constitution:
After the G.M. is over, the new Committee shall select from its number a Chairman, Secretary and Treasurer, together with additional Committee posts as required.
At the meeting David Crump stated that he wished to step down as chair, Brian Summers stated that he wished to step down as treasurer and Noel Matthews confirmed he was happy to serve another term as secretary.
As a result, the following appointments were proposed and agreed unanimously by the committee.
Martin Charman will be chair of BATC with immediate effect and David Crump will be treasurer.
As mentioned at the GM we do intend to discuss publishing committee meeting minutes and if agreed the full minutes of the meeting will be published.
Noel Matthews
BATC secretary.
G0LJF
Re: Minutes and chairman's report
Post by G0LJF » Thu Aug 25, 2022 10:00 am
May I please thank everyone for their obvious hard work, and especially time, that they have dedicated to BATC. Its a fine club.
I for one will not forget this, for past and future organisers and active BATC people / members of committees.
73,
G0LJF
G4FRE
Post by G4FRE » Mon Oct 17, 2022 3:02 pm
The link to the chairmans 2022 report which points to https://wiki.batc.org.uk/CAT_22_part_1 is broken and results in the following response :-
[a804b86caf5bc08c0010b14b] /CAT_22_part_1 MWException from line 1259 of /srv/wiki/includes/WebRequest.php: WebRequest::getRawIP : Could not determine the remote IP address due to multiple values.
Backtrace:
#0 /srv/wiki/includes/WebRequest.php(1286): WebRequest->getRawIP()
#1 /srv/wiki/includes/Setup.php(652): WebRequest->getIP()
#2 /srv/wiki/includes/WebStart.php(89): require_once(string)
#3 /srv/wiki/index.php(44): require(string)
#4 {main}
the link to the pdf with the 2022 minutes works fine
g4fre
Return to “CAT 22 - Online 22 October 2022”
