CAT 22 Test and Fix-it
Posted: Wed Aug 03, 2022 3:22 pm
I am just putting together the equipment that I will bring for the test and fix-it bench at CAT 22 this Sunday.
I plan to bring enough gear to test and diagnose most faults in Portsdown and Ryde equipment. I will also be able to give an indication of the Power Output of transmitters (up to 100W from 50 MHz to 10 GHz) and estimate (+/- 2 dB up to 24 GHz) the noise figure of receiving equipment.
There should be a QO-100 IF feed available for receiver testing.
If anybody has any very specific requests for testing, please post them here.
Remember to bring power supplies and all connecting leads (power and RF) with you as sometimes the faults are in the power supplies or the connectors!
