winterhill receptionof frequensies
Hello all. I have the winterhill receiver. Now i was able to receive my own signal on 70cm and 23 cm on vlc1 and vlc2. I dont remember how i got it to work. Maybe one of you can tell me how to get this possible again. I use the winterhill with four times vlc started. I have a program on my pc where i should be able to change the frequensies on the winterhill. However the winterhill doesn,t react on it like it used to do before. Please help?
Re: winterhill receptionof frequensies
I assume you're using whpcrxcom on the PC to send commands to WH.
The IP address in whpcrxcom should match the IP address of the WH RPi There's an icon on the RPi desktop which will tell you its IP address.
Are your VLC windows on the RPi or the PC?
Can you post some screenshots of your setup.
