Install Problem
Re: Install Problem
Very good. I've used three 1920 x 1080 TVs in the house without problems.
It would be interesting to put the TV back in and when the problem occurs, unplug it from the HDMI port and see if things start to work.
Re: Install Problem
Brian,
I have been at this for two days now so I now need a break - my TV is now back where it belongs - away from here and attached to the DVBT2 PVR.
Can you "hot plug" HDMI? I never do, being cautious.
73 for now,
73 for now,
Re: Install Problem
Apparently you can Hot-Plug HDMI - still, its not for me. Why risk it?
You can Hot Plug USB too - but I had a (expensive 8 core development) PC at work instantly ruined by someone else hot plugging my USB !
Never let anyone else near your PC.
Re: Install Problem
I have just finished building my WinterHill, but I’m having a problem with the software. I have built the SD card including the “ssh” file and all seems okay, Pi boots up fine. Then using Putty to cut and paste the lines of code, one at a time. The down load starts, but then fails.
inflating: winterhill-main/whsource-3v20/whmain-3v20/stvvglna_utils.h
inflating: winterhill-main/whsource-3v20/whpicprog-3v20/make.sh
inflating: winterhill-main/whsource-3v20/whpicprog-3v20/whpic-3v20.hex
inflating: winterhill-main/whsource-3v20/whpicprog-3v20/whpicprog-3v20.c
inflating: winterhill-main/whstop-3v20.sh
inflating: winterhill-main/winterhill-notes-3v20a.txt
inflating: winterhill-main/winterhill.ini
mv: cannot move 'winterhill-main' to 'winterhill/winterhill-main': Directory not empty
---- Building spi driver for install -----
make -C /lib/modules/5.10.17-v7l+/build/ M=/home/pi/winterhill/whsource-3v20/whdriver-3v20 modules
make[1]: *** /lib/modules/5.10.17-v7l+/build/: No such file or directory. Stop.
make: *** [Makefile:4: all] Error 2
- Failed to build the WinterHill Driver –
I’m not too sure where I have gone wrong, I have rebuilt the SD card twice now and following procedure in the installation Manual -3v20a Rev1 to the letter. So what have I missed?
Ken G4BVK
Ken G4BVK
Re: Install Problem
Possibly nothing, Have you tried building it plugged directly into your main router? It was the only way until I replaced a cheap hub in the shack with a Belkin one, ironically culled from a recycling skip when the operatives were not looking.
Re: Install Problem
It seems to go wrong at:
This is trying to rename the winterhill-main folder, where the unzipping occurred, to winterhill. It seems to think there already is a winterhill folder, which shouldn't be the case.
Can you post the output from: (-l is lower case L)
cd /home/pi
ls -l
If you see a winterhill folder:
cd winterhill
ls -l
cd /home/pi
ls -l
cd winterhill
ls -l
Re: Install Problem
Hi both,
Both the PC and the Pi are plug into the same router. I ran the code as you suggested Brian. It did show a "winterhill", what is that telling us?
Ken
pi@raspberrypi:~ $ cd /home/pi
pi@raspberrypi:~ $ ls -l
total 140
drwxr-xr-x 2 pi pi 4096 Mar 4 22:57 Bookshelf
drwxr-xr-x 2 pi pi 4096 Mar 4 23:27 Desktop
drwxr-xr-x 2 pi pi 4096 Mar 4 23:27 Documents
drwxr-xr-x 2 pi pi 4096 Mar 4 23:27 Downloads
-rwxr-xr-x 1 pi pi 8307 Apr 25 16:40 install_winterhill.sh
-rw-r--r-- 1 pi pi 8307 Apr 26 10:11 install_winterhill.sh.1
-rw-r--r-- 1 pi pi 8307 Apr 26 10:14 install_winterhill.sh.2
-rw-r--r-- 1 pi pi 8307 Apr 26 10:22 install_winterhill.sh.3
-rw-r--r-- 1 pi pi 8307 Apr 26 10:23 install_winterhill.sh.4
-rw-r--r-- 1 pi pi 8307 Apr 26 10:26 install_winterhill.sh.5
-rw-r--r-- 1 pi pi 8307 Apr 26 10:56 install_winterhill.sh.6
-rw-r--r-- 1 pi pi 8307 Apr 26 10:58 install_winterhill.sh.7
drwxr-xr-x 2 pi pi 4096 Mar 4 23:27 Music
drwxr-xr-x 2 pi pi 4096 Mar 4 23:27 Pictures
drwxr-xr-x 2 pi pi 4096 Mar 4 23:27 Public
drwxr-xr-x 2 pi pi 4096 Mar 4 23:27 Templates
drwxr-xr-x 2 pi pi 4096 Mar 4 23:27 Videos
drwxr-xr-x 8 pi pi 4096 Apr 26 10:14 winterhill
drwxr-xr-x 7 pi pi 4096 Apr 26 10:59 winter
pi@raspberrypi:~ $ cd winterhill
pi@raspberrypi:~/winterhill $ ls -l
total 80
drwxr-xr-x 2 pi pi 4096 Mar 23 19:46 configs
-rw-r--r-- 1 pi pi 10 Mar 23 19:46 installed_version.txt
-rwxr-xr-x 1 pi pi 8307 Mar 23 19:46 install_winterhill.sh
-rw-r--r-- 1 pi pi 10 Mar 23 19:46 latest_version.txt
drwxr-xr-x 2 pi pi 4096 Mar 23 19:46 PIC-3v20
-rw-r--r-- 1 pi pi 2276 Mar 23 19:46 README.md
drwxr-xr-x 2 pi pi 4096 Mar 23 19:46 RPi-3v20
-rwxr-xr-x 1 pi pi 1700 Mar 23 19:46 startup.sh
-rwxr-xr-x 1 pi pi 8049 Mar 23 19:46 update.sh
drwxr-xr-x 2 pi pi 4096 Mar 23 19:46 utils
-rw-r--r-- 1 pi pi 256 Mar 23 19:46 version_history.txt
-rw-r--r-- 1 pi pi 89 Apr 26 10:59 whlog.txt
drwxr-xr-x 5 pi pi 4096 Mar 23 19:46 whsource-3v20
-rwxr-xr-x 1 pi pi 566 Mar 23 19:46 whstop-3v20.sh
-rw-r--r-- 1 pi pi 2510 Mar 23 19:46 winterhill.ini
drwxr-xr-x 7 pi pi 4096 Mar 23 19:46 winterhill-main
-rw-r--r-- 1 pi pi 3176 Mar 23 19:46 winterhill-notes-3v20a.txt
Ken
total 140
total 80
Re: Install Problem
It looks like the WH software install has been done more than once, which maybe it has.
The winterhill folder appears to have the correct folders inside, with the addition of the winterhill-main folder. The winterhill-main folder couldn't be renamed to the winterhill folder because a winterhill folder already existed, so winterhill-main was copied into the existing winterhill folder.
There is also a folder called winter, which I don't recognise.
Try this below. It may complain, because some system files that it was expecting to change have already changed, but see how far it gets. Only do it the once. If it fails, do the two ls -l lines as in the previous post.
cd /home/pi
mv winterhill winterhillxxx
That will effectively get rid of the winterhill folder.
./install_winterhill.sh
cd /home/pi
Re: Install Problem
Hi Brian,
Ran that and it still fails at the same place.
Ken
Ken
Re: Install Problem
It failed at this line?
Did you get this line again?
sudo find / -iname 'build'
We can do a Zoom call later if you like - if you can set one up. I've only used Zoom once.
