Knucker via LAN
g8lce
Knucker via LAN
Post by g8lce » Fri Apr 02, 2021 1:53 pm
Just tried using Knucker to receive 437MHz from Pluto on a LAN connection transmitting from a Portsdown 4. It does not work apart from the fact it transmits the DVB-S signal instead.
So there is a difference in using the Pluto connected directly and via a LAN connection when thinking about DVB-T which is no surprise.
G1LPS Terry
Re: Knucker via LAN
Post by G1LPS Terry » Fri Apr 02, 2021 7:42 pm
Hi Martin
I only use a LAN connection to my Pluto and everything works with Portsdown 4.
No issues here with transmitting DVB-T.
Terry G1LPS
g8lce
Re: Knucker via LAN
Post by g8lce » Sat Apr 03, 2021 6:25 pm
You are right! Just got it to TX testcard, PiCam and C920 Webcam.
