Repeater ON0TVO with ryde to scan 6m and 10m on 1 Ryde receiver
Posted: Mon Dec 08, 2025 6:55 pm
by ON5KR
Hi All,
How do i configure the yaml file to scan 51.700MHz 125Ks and 250Ks and 10m 125Ks and 250Ks ? Both with correction for converter?
The one on A and the other on B?
Is that possible?
People who want to see the repeater srt://srt.on0tvo.be:10000
Greetings,
ON5KR
Re: Repeater ON0TVO with ryde to scan 6m and 10m on 1 Ryde receiver
Posted: Tue Dec 09, 2025 11:25 am
by Pa3fbx
Hello, Basically you cannot..
You cannot select the port TOP/Bottom in 1 selection..
You can select several Symbol rates and/or frequencies to scan in a preselection but to select an other port you need a new preselect.
This is exactly what the other discussion was about.
viewtopic.php?f=130&t=9313
So you must figure out a way to change the preselect (channel + or -)
One way would be deleting all the preselections and only leave the 2 you need.
Than you toggle the channel + or - button GPIO to select either preselect..
Or you need some remote control like i made in our pi6mep repeater with node-red commands..
creating a TCP message.
Let me know if you have more Q's.
Benno, PA3FBX.
Posted: Tue Dec 09, 2025 8:30 pm
by ON5KR
Thank you Benno!
I will look into it.
Kind regards,
73's ON5KR
Posted: Sat Dec 20, 2025 6:22 pm
by Pa3fbx
I have continued playing witch Json messages via the network and found more solutions.
So now i added buttons to the web control for various receiver modes..
So setting frequency, Sample rates, scans, bands and even receiver ports or internet streams.
All can be done with the right Json tcp message.
The main question, do you have acces to the network port and can you send a network command.
Benno
