Ryde HDMI to encoder problems
Posted: Thu Dec 07, 2023 10:21 am
I have been using a Ryde receiver HDMI output into a H265 encoder box to stream to the BATC streamer for years (H264 mode). I have also used another H265 encoder fed from a satellite RX HDMI, to allow a VLC feed of the same repeater. (rtsp://82.144.238.35:8889/live/0).
I have just started changing things and found that the VLC rtsp feed from the encoder fed from the Ryde has no audio. Tried many things but this seems to be the case. It may be because the Ryde audio is 32kb/s and although the encoder will switch to this, it does not come out on the rtsp stream.
Any other HDMI input seems to work but also has a higher bit rate (48kb/s).
During the investigation I found a useful site for control and updating of these encoders.
https://docs.exvist.com/encoder/upgrade ... d-firmware
I used the link to get the ipcmanger https://docs.exvist.com/encoder/tools/i ... r/download
and that worked well, finding the encoders and allowing the firmware updates. You do have to read ALL the information (as I missed the serial number bit at first). If you try the wrong upload it seems to fail not brick! The latest firmware updated my oldest encoder so the Active X is now replaced by HTML 5 preview.
Hope this helps
Hope this helps
