Use 7" touchscreen
PE5PVB
Use 7" touchscreen
Post by PE5PVB » Tue Aug 09, 2022 8:10 am
Is it possible to use the 7" touchscreen (from the portsdown project) to watch and control the Ryde receiver?
Re: Use 7" touchscreen
Post by g0mjw » Tue Aug 09, 2022 8:50 am
No.
MW0RUD
Post by MW0RUD » Tue Aug 09, 2022 8:52 am
It is not possible to control the Ryde with the touch screen.
I have heard unofficial reports that watching works but this isn't an official configuration so if you have problems you are on your own.
Tim
Post by g0mjw » Tue Aug 09, 2022 9:02 am
If you want to watch signals on the 7 inch screen and control it from there, a solution might be simply to install the Portsdown Software, which does this as standard.
PE5PVB
Post by PE5PVB » Tue Aug 09, 2022 9:17 am
Ah ok. simple ;-)
Does this also show H265 streams?
Post by g0mjw » Tue Aug 09, 2022 9:35 am
It shows a single H265 stream at a time, like the Ryde. I am not sure if there are any other additional limitations, apart from the remote control, but as a bonus you can control it via a web page.
There is a Wiki that answers all of these questions and many more that should be the first place to look https://wiki.batc.org.uk/BATC_Wiki
