Customising the Red Not Locked Screen
Posted: Thu Aug 04, 2022 1:16 pm
We use 3 of these for our repeater how easy would it be to prefix the Not Locked with 2m so it reads 2m Not Locked?
Thanks Paul
Thanks Paul
NOTE - all postings remain the copyright of the author, please get their permission before publishing elsewhere. To report online abuse: https://batc.org.uk/club-info/uk-on-line-safety-act/
https://forum.batc.org.uk/
# Ryde Player provides a on screen interface and video player for Longmynd compatible tuners.
# Copyright © 2021 Tim Clark
# This program is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program. If not, see <https://www.gnu.org/licenses/>.
import pygame, vlc, select, pydispmanx, yaml, os, pkg_resources, argparse, importlib, functools, sys
import rydeplayer.sources.common
import rydeplayer.sources.longmynd
import rydeplayer.sources.combituner
from . import ir
import rydeplayer.gpio
import rydeplayer.network
import rydeplayer.common
import rydeplayer.states.gui
import rydeplayer.states.playback
import rydeplayer.osd.display
import rydeplayer.osd.modules
# container for the theme
class Theme(object):
def __init__(self, displaySize):
self.colours = type('colours', (object,), {
'transparent': (0,0,0,0),
'transpBack': (0,0,0,51),
'black': (0,0,0,255),
'white': (255,160,0,255),
'red': (255,0,0,255),
'textError': (255,0,0,255),
'backgroundMenu': (192,192,192,255),
'backgroundSubMenu': (160,160,160,255),
'backgroundPlayState': (160,160,160,255),
self.displayWidth = int(displaySize[0])
self.displayHeight = int(displaySize[1])
self.menuWidth = int(self.displayWidth/4)
self.menuHeight = self.displayHeight
playStateTitleFontSize=self.fontSysSizeOptimize('Not Loaded', displaySize[0]/2, 'freesans')
menuH1FontSize=self.fontSysSizeOptimize('BATC Ryde Project', self.menuWidth*0.85, 'freesans')
self.fonts = type('fonts', (object,), {
'menuH1': pygame.font.SysFont('freesans', menuH1FontSize),
'playStateTitle' : pygame.font.SysFont('freesans', playStateTitleFontSize),
self._circlecache = {}
self.logofile = pkg_resources.resource_stream('rydeplayer.resources', 'logo_menu.png')
self.muteicon = pkg_resources.resource_stream('rydeplayer.resources', 'icon_mute.png')
# calculate the largest font size that you can render the given test in as still be less than width
def fontSysSizeOptimize(self, text, width, fontname):
fontsize = -1
while True:
fontCandidate = pygame.font.SysFont(fontname, fontsize+1)
fontwidth = fontCandidate.size(text)[0]
del(fontCandidate)
if(fontwidth > width):
break
else:
fontsize += 1
return fontsize
# calculate the largest font size that has a line height less than height
def fontSysSizeOptimizeHeight(self, height, fontname):
fontsize = -1
while True:
fontheight = fontCandidate.get_linesize()
del(fontCandidate)
if(fontheight > height):
break
else:
fontsize += 1
return fontsize
# size and position a pygame rectangle using screen size independent units and a datum corner
def relativeRect(self, datum, xEdgeDistance, yEdgeDistance, width, height):
outwidth = self.displayHeight*width
outheight = self.displayHeight*height
if datum is rydeplayer.common.datumCornerEnum.TR:
outX = self.displayWidth - ((xEdgeDistance+width)*self.displayHeight)
outY = yEdgeDistance*self.displayHeight
elif datum is rydeplayer.common.datumCornerEnum.TC:
outX = (self.displayWidth/2) - (((width/2)-xEdgeDistance)*self.displayHeight)
elif datum is rydeplayer.common.datumCornerEnum.TL:
outX = xEdgeDistance*self.displayHeight
elif datum is rydeplayer.common.datumCornerEnum.CR:
outY = (self.displayHeight/2) - (((height/2)-yEdgeDistance)*self.displayHeight)
elif datum is rydeplayer.common.datumCornerEnum.CC:
elif datum is rydeplayer.common.datumCornerEnum.CL:
elif datum is rydeplayer.common.datumCornerEnum.BR:
outY = self.displayHeight - ((yEdgeDistance+height)*self.displayHeight)
elif datum is rydeplayer.common.datumCornerEnum.BC:
elif datum is rydeplayer.common.datumCornerEnum.BL:
return pygame.Rect((outX, outY, outwidth, outheight))
# helper function for outline font rendering
def _circlepoints(self,r):
r = int(round(r))
if r in self._circlecache:
return self._circlecache[r]
x, y, e = r, 0, 1 - r
self._circlecache[r] = points = []
while x >= y:
points.append((x, y))
y += 1
if e < 0:
e += 2 * y - 1
else:
x -= 1
e += 2 * (y - x) - 1
points += [(y, x) for x, y in points if x > y]
points += [(-x, y) for x, y in points if x]
points += [(x, -y) for x, y in points if y]
points.sort()
return points
# render font with different coloured outline
def outlineFontRender(self, text, font, gfcolor, ocolor, opx=2):
textsurface = font.render(text, True, gfcolor)
w = textsurface.get_width() + 2 * opx
h = font.get_height()
osurf = pygame.Surface((w, h + 2 * opx), pygame.SRCALPHA)
osurf.fill((0, 0, 0, 0))
surf = osurf.copy()
osurf.blit(font.render(text, True, ocolor), (0, 0))
for dx, dy in self._circlepoints(opx):
surf.blit(osurf, (dx + opx, dy + opx))
surf.blit(textsurface, (opx, opx))
return surf
# power menu UI state machine
class SubMenuPower(rydeplayer.states.gui.ListSelect):
def __init__(self, theme, backState, shutdownCallback):
items = {
rydeplayer.common.shutdownBehavior.APPSTOP : 'App Shutdown',
rydeplayer.common.shutdownBehavior.APPREST : 'App Restart',
rydeplayer.common.shutdownBehavior.SYSSTOP : 'System Shutdown',
rydeplayer.common.shutdownBehavior.SYSREST : 'System Restart',
super().__init__(theme, backState, items, lambda: rydeplayer.common.shutdownBehavior.APPSTOP, shutdownCallback)
def get_event(self, event):
if super().get_event(event):
return True
else:
if event == rydeplayer.common.navEvent.POWER:
return super().get_event(rydeplayer.common.navEvent.SELECT)
else:
return False
# main UI state machine
class guiState(rydeplayer.states.gui.SuperStates):
def __init__(self, theme, shutdownBehaviorDefault, player, osd):
super().__init__(theme)
self.done = False
self.player = player
self.osd = osd
self.shutdownBehaviorDefault = shutdownBehaviorDefault
self.shutdownState = rydeplayer.common.shutdownBehavior.APPSTOP
# callback to run all the remove and cleanup callback on the active manu states
def _cleanupMenuStates(self, activeCallbacks):
for callback in activeCallbacks:
callback()
# generate the menu states based on current config capabilites
def _genMenuStates(self, config, debugFunctions, superMenu):
# get variables for current config
tunerConfigVars = config.tuner.getVars()
# generate config specific menu items
mainMenuStates = {}
firstkey = None
lastkey = None
# set of cleanup functions for the menu items
activeCallbacks = set()
for key in tunerConfigVars:
validVar = False
# create sub menu items for supported var types
if isinstance(tunerConfigVars[key], rydeplayer.sources.common.tunerConfigIntList):
mainMenuStates[key+'-sel'] = rydeplayer.states.gui.MultipleNumberSelect(self.theme, key, tunerConfigVars[key], config.tuner.runCallbacks)
validVar = True
if isinstance(tunerConfigVars[key], rydeplayer.sources.common.tunerConfigInt):
mainMenuStates[key+'-sel'] = rydeplayer.states.gui.NumberSelect(self.theme, key, tunerConfigVars[key], config.tuner.runCallbacks)
validVar = True
if validVar:
if firstkey is None:
firstkey = key
if lastkey is None:
lastkey = key
# create menu item
mainMenuStates[key] = rydeplayer.states.gui.MenuItem(self.theme, tunerConfigVars[key].getLongName(), lastkey, firstkey, key+'-sel', tunerConfigVars[key])
mainMenuStates[lastkey].down = key
mainMenuStates[firstkey].up = key
lastkey = key
# callback to menu header for validity updates
validCallFunc = functools.partial(superMenu.redrawState, mainMenuStates[key], mainMenuStates[key].getSurfaceRects())
tunerConfigVars[key].addValidCallback(validCallFunc)
activeCallbacks.add(functools.partial(tunerConfigVars[key].removeValidCallback,validCallFunc))
cleanupFunc = functools.partial(self._cleanupMenuStates, activeCallbacks)
# main menu states, order is important to get menus and sub menus to display in the right place
firstkey = 'band'
if lastkey is None:
lastkey = 'power'
baseMenuStates = {
'band-sel' : rydeplayer.states.gui.ListSelect(self.theme, 'band', config.bands, config.tuner.getBand, config.tuner.setBand),
'band' : rydeplayer.states.gui.MenuItem(self.theme, "Band", lastkey, "preset", "band-sel"),
'preset-sel' : rydeplayer.states.gui.ListSelect(self.theme, 'preset', config.presets, lambda:config.tuner, config.tuner.setConfigToMatch),
'preset' : rydeplayer.states.gui.MenuItem(self.theme, "Presets", "band", "power", "preset-sel"),
'power-sel' : SubMenuPower(self.theme, 'power', self.shutdown),
'power' : rydeplayer.states.gui.MenuItem(self.theme, "Power", "preset", firstkey, "power-sel"),
mainMenuStates.update(baseMenuStates)
mainMenuStates[lastkey].down = 'band'
mainMenuStates[firstkey].up = 'power'
lastkey = 'power'
# add debug menu if enabled in config
if config.debug.enableMenu:
# generate debug menu states
debugMenuStates = {}
debugPrevState = None
debugFirstState = None
for key in debugFunctions:
menukey = key.strip().replace(" ", "").lower()
if debugFirstState is None:
debugFirstState = menukey
debugPrevState = menukey
debugMenuStates[menukey] = rydeplayer.states.gui.SubMenuItemFunction(self.theme, key, debugPrevState, debugFirstState, debugFunctions[key])
debugMenuStates[debugPrevState].down = menukey
debugMenuStates[debugFirstState].up = menukey
mainMenuStates['debug-sel'] = rydeplayer.states.gui.SubMenuGeneric(self.theme, 'debug', debugMenuStates, debugFirstState)
mainMenuStates['debug'] = rydeplayer.states.gui.MenuItem(self.theme, "Debug", lastkey, firstkey, "debug-sel")
mainMenuStates[lastkey].down = 'debug'
mainMenuStates[firstkey].up = 'debug'
lastkey = 'debug'
validCallFunc = superMenu.refreshStates
config.tuner.addVarChangeCallbackFunction(validCallFunc)
activeCallbacks.add(functools.partial(config.tuner.removeVarChangeCallbackFunction,validCallFunc))
return (mainMenuStates, firstkey, cleanupFunc)
def startup(self, config, debugFunctions):
# top level state machine
self.state_dict = {
'menu': rydeplayer.states.gui.Menu(self.theme, 'home', functools.partial(self._genMenuStates, config, debugFunctions)),
'home': Home(self.theme, self.osd)
self.state_name = "home"
self.state = self.state_dict[self.state_name]
self.state.startup()
def shutdown(self, shutdownState):
self.shutdownState = shutdownState
self.state.cleanup()
self.done = True
if not self.state.get_event(event):
self.setStateStack([self.shutdownBehaviorDefault,'power-sel','menu'])
elif event == rydeplayer.common.navEvent.OSDON:
self.osd.activate(1)
elif event == rydeplayer.common.navEvent.OSDOFF:
self.osd.deactivate(1)
elif event == rydeplayer.common.navEvent.OSDTOG:
self.osd.toggle(2)
elif(event == rydeplayer.common.navEvent.MUTE):
self.player.toggleMute()
elif(event == rydeplayer.common.navEvent.VOLU):
self.player.adjustVolumeByStep(True)
self.player.setMute(False)
self.osd.activate(3, rydeplayer.osd.display.TimerLength.USERTRIGGER)
elif(event == rydeplayer.common.navEvent.VOLD):
self.player.adjustVolumeByStep(False)
elif(event == rydeplayer.common.navEvent.CHANU):
self.player.switchPresetRelative(-1)
elif(event == rydeplayer.common.navEvent.CHAND):
self.player.switchPresetRelative(1)
# GUI state for when the menu isnt showing
class Home(rydeplayer.states.gui.States):
def __init__(self, theme, osd):
self.next = 'menu'
self.osd = osd
def cleanup(self):
None
def startup(self):
None
#TODO: add OSD state machine
if(event == rydeplayer.common.navEvent.SELECT):
elif(event == rydeplayer.common.navEvent.BACK):
self.osd.deactivate(2)
elif(event == rydeplayer.common.navEvent.MENU):
self.done = True
class rydeConfig(object):
def __init__(self, theme):
self.ir = ir.irConfig()
self.gpio = rydeplayer.gpio.gpioConfig()
self.tuner = rydeplayer.sources.common.tunerConfig()
# source specific config
self.sourceConfigs = dict()
for thisSource in rydeplayer.sources.common.sources:
self.sourceConfigs[thisSource]=thisSource.getSource().getConfig()()
self.bands = {}
defaultBand = self.tuner.getBand()
self.bands[defaultBand] = "None"
self.presets = {}
self.osd = rydeplayer.osd.display.Config(theme)
self.network = rydeplayer.network.networkConfig()
self.shutdownBehavior = rydeplayer.common.shutdownBehavior.APPSTOP
self.audio = type('audioConfig', (object,), {
'muteOnStartup': False,
'volumeOnStartup': 100,
'volumeStep': 25,
self.debug = type('debugConfig', (object,), {
'enableMenu': False,
'autoplay': True,
'disableHardwareCodec': True,
self.configRev = 3
#setter for default values
def setAutoplay(self, newval):
self.debug.autoplay = newval
# parse config dict
def loadConfig(self, config):
perfectConfig = True
if isinstance(config, dict):
# parse config revision
if 'configRev' in config:
if isinstance(config['configRev'], int):
if config['configRev'] != self.configRev:
print("Unmatched config revision, config load aborted")
return False
else:
print("Config revision not an integer, config load aborted")
return False
else:
print("WARNING: no config revision present, config load my fail")
if 'bands' in config:
if isinstance(config['bands'], dict):
newBands = {}
exsistingBands = list(self.bands.keys())
for bandName in config['bands']:
bandDict = config['bands'][bandName]
bandParseSuccess, bandObject = rydeplayer.sources.common.tunerBand.loadBand(bandDict)
if bandParseSuccess:
# dedupe band object with exsisting library
if bandObject in exsistingBands:
bandObject = exsistingBands[exsistingBands.index(bandObject)]
newBands[bandObject] = str(bandName)
else:
perfectConfig = False
if len(newBands) > 1:
self.bands = newBands
else:
print("No valid bands, skipping")
else:
print("Invalid band library")
# parse source specific configs
if 'sources' in config:
if isinstance(config['sources'], dict):
if thisSource.name.lower() in config['sources']:
perfectConfig = perfectConfig and self.sourceConfigs[thisSource].loadConfig(config['sources'][thisSource.name.lower()])
elif thisSource.name.upper() in config['sources']:
perfectConfig = perfectConfig and self.sourceConfigs[thisSource].loadConfig(config['sources'][thisSource.name.upper()])
else:
print("Sources config not a dict")
# parse presets
if 'presets' in config:
if isinstance(config['presets'], dict):
newPresets = {}
exsistingPresets = list(self.presets.keys())
for presetName in config['presets']:
presetDict = config['presets'][presetName]
presetObject = rydeplayer.sources.common.tunerConfig()
if presetObject.loadConfig(presetDict, list(self.bands.keys())):
# dedupe preset object with exsisting library
if presetObject in exsistingPresets:
presetObject = exsistingPresets[exsistingPresets.index(presetObject)]
newPresets[presetObject] = str(presetName)
else:
if len(newPresets) > 1:
self.presets = newPresets
else:
print("No valid presets, skipping")
else:
print("Invalid preset library")
# pass default tuner config to be parsed by longmynd module
if 'default' in config:
defaultPreset = rydeplayer.sources.common.tunerConfig()
# perfectConfig = perfectConfig and defaultPreset.loadConfig(config['default'], list(self.bands.keys()))
if defaultPreset.loadConfig(config['default'], list(self.bands.keys())):
if defaultPreset in exsistingPresets:
defaultPreset = exsistingPresets[exsistingPresets.index(defaultPreset)]
self.tuner.setConfigToMatch(defaultPreset)
else:
# pass ir config to be parsed by the ir config container
if 'ir' in config:
perfectConfig = perfectConfig and self.ir.loadConfig(config['ir'])
# pass the gpio config to be parsed by the gpio config container
if 'gpio' in config:
perfectConfig = perfectConfig and self.gpio.loadConfig(config['gpio'])
# pass the osd config to be parsed by the osd config container
if 'osd' in config:
perfectConfig = perfectConfig and self.osd.loadConfig(config['osd'])
# pass the network config to be parsed by the network config container
if 'network' in config:
perfectConfig = perfectConfig and self.network.loadConfig(config['network'])
# parse shutdown default shutdown event behavior
if 'shutdownBehavior' in config:
if isinstance(config['shutdownBehavior'], str):
validShutBehav = False
for shutBehavOpt in rydeplayer.common.shutdownBehavior:
if shutBehavOpt.name == config['shutdownBehavior'].upper():
self.shutdownBehavior = shutBehavOpt
validShutBehav = True
break
if not validShutBehav:
print("Shutdown behavior default invalid, skipping")
else:
# parse audio options
if 'audio' in config:
if isinstance(config['audio'], dict):
if 'muteOnStartup' in config['audio']:
if isinstance(config['audio']['muteOnStartup'], bool):
self.audio.muteOnStartup = config['audio']['muteOnStartup']
else:
print("Invalid mute on startup config, skipping")
if 'volumeOnStartup' in config['audio']:
if isinstance(config['audio']['volumeOnStartup'], int):
if config['audio']['volumeOnStartup'] <= 100 and config['audio']['volumeOnStartup'] >= 0:
self.audio.volumeOnStartup = config['audio']['volumeOnStartup']
else:
print("Invalid startup volume config, out of range, skipping")
else:
print("Invalid startup volume config, skipping")
if 'volumeStep' in config['audio']:
if isinstance(config['audio']['volumeStep'], int):
if config['audio']['volumeStep'] <= 100 and config['audio']['volumeStep'] >= 0:
self.audio.volumeStep = config['audio']['volumeStep']
else:
print("Invalid volume step config, out of range, skipping")
else:
print("Invalid volume step config, skipping")
# parse debug options
if 'debug' in config:
if isinstance(config['debug'], dict):
if 'enableMenu' in config['debug']:
if isinstance(config['debug']['enableMenu'], bool):
self.debug.enableMenu = config['debug']['enableMenu']
else:
print("Invalid debug menu config, skipping")
if 'autoplay' in config['debug']:
if isinstance(config['debug']['autoplay'], bool):
self.debug.autoplay = config['debug']['autoplay']
else:
print("Invalid debug autoplay config, skipping")
if 'disableHardwareCodec' in config['debug']:
if isinstance(config['debug']['disableHardwareCodec'], bool):
self.debug.disableHardwareCodec = config['debug']['disableHardwareCodec']
else:
print("Invalid debug hardware codec config, skipping")
else:
print("Invalid debug config, skipping")
else:
print("Invalid config, no fields")
return perfectConfig
# load yaml config file
def loadFile(self, path):
if os.path.exists(path) and os.path.isfile(path):
try:
with open(path, 'r') as ymlconfigfile:
self.loadConfig(yaml.load(ymlconfigfile))
except IOError as e:
print(e)
else:
print("config file not found")
class player(object):
def __init__(self, configFile = None):
# Autodetect output display
if(len(pydispmanx.getDisplays())<1):
raise RuntimeError('No displays detected')
else:
self.displayId = pydispmanx.getDisplays()[0]
# setup ui core
pygame.init()
self.theme = Theme(pydispmanx.getDisplaySize())
self.playbackState = rydeplayer.states.playback.StateDisplay(self.theme)
print(pygame.font.get_fonts())
# load config
self.config = rydeConfig(self.theme)
if configFile != None:
self.config.loadFile(configFile)
print(self.config.tuner)
# mute
self.mute = self.config.audio.muteOnStartup
self.muteCallbacks = []
# volume
self.volume = self.config.audio.volumeOnStartup
self.volumeCallbacks = []
# setup source
self.sourceMan = rydeplayer.sources.common.sourceManagerThread(self.config.tuner, self.config.sourceConfigs)
self.config.tuner.addCallbackFunction(self.sourceMan.reconfig)
self.vlcStartup()
# setup on screen display
self.osd = rydeplayer.osd.display.Controller(self.theme, self.config.osd, self.sourceMan.getStatus(), self, self.config.tuner)
debugFunctions = {'Restart Source':self.sourceMan.restart, 'Force VLC':self.vlcStop, 'Abort VLC': self.vlcAbort}
# start ui
self.app = guiState(self.theme, self.config.shutdownBehavior, self, self.osd)
self.app.startup(self.config, debugFunctions)
# start network
self.netMan = rydeplayer.network.networkManager(self.config, self.stepSM, self.setMute, debugFunctions)
# setup ir
self.irMan = ir.irManager(self.stepSM, self.config.ir)
# setup gpio
self.gpioMan = rydeplayer.gpio.gpioManager(self.stepSM, self.config.gpio, self.config.tuner)
self.config.tuner.addCallbackFunction(self.gpioMan.setBandOutFromPreset)
# start source
self.sourceMan.start()
print("Ready")
self.monotonicState = 0;
def start(self):
quit = False
# main event loop
while not quit:
# need to regen every loop, lm stdout handler changes on lm restart
fds = self.irMan.getFDs() + self.sourceMan.getFDs() + self.gpioMan.getFDs() + self.osd.getFDs() + self.netMan.getFDs()
r, w, x = select.select(fds, [], [])
for fd in r:
quit = self.handleEvent(fd)
self.updateState()
if quit:
break
self.shutdown(self.app.shutdownState)
def addMuteCallback(self, callback):
self.muteCallbacks.append(callback)
def removeMuteCallback(self, callback):
self.muteCallbacks.remove(callback)
def setMute(self,newMute):
if self.mute != newMute:
self.mute = newMute
self.vlcPlayer.audio_set_mute(newMute)
for callback in self.muteCallbacks:
callback(newMute)
def getMute(self):
return self.mute
def toggleMute(self):
self.setMute(not self.mute)
def addVolumeCallback(self, callback):
self.volumeCallbacks.append(callback)
def removeVolumeCallback(self, callback):
self.volumeCallbacks.remove(callback)
def setVolume(self,newVolume):
if newVolume > 100:
newVolume = 100
elif newVolume < 0:
newVolume = 0
if self.volume != newVolume:
self.volume = newVolume
self.vlcPlayer.audio_set_volume(newVolume)
for callback in self.volumeCallbacks:
callback(newVolume)
def getVolume(self):
return self.volume
def adjustVolume(self, volumeAdjustment):
self.setVolume(self.volume + volumeAdjustment)
def adjustVolumeByStep(self, up):
if up:
self.adjustVolume(self.config.audio.volumeStep)
else:
self.adjustVolume(-self.config.audio.volumeStep)
def getPresetName(self, preset):
if preset in self.config.presets:
return str(self.config.presets[preset])
else:
return ""
def switchPresetRelative(self, offset):
presetkeys = list(self.config.presets.keys())
if len(presetkeys) > 0:
newindex = None
if self.config.tuner in presetkeys:
newindex = (presetkeys.index(self.config.tuner) + offset)%len(presetkeys)
else:
if offset > 0:
newindex = 0
elif offset < 0:
newindex = len(presetkeys)-1
if newindex is not None:
self.config.tuner.setConfigToMatch(presetkeys[newindex])
def shutdown(self, behaviour):
del(self.osd)
del(self.playbackState)
self.sourceMan.shutdown()
if behaviour is rydeplayer.common.shutdownBehavior.APPREST:
os.execv(sys.executable, ['python3', '-m', 'rydeplayer'] + sys.argv[1:])
elif behaviour is rydeplayer.common.shutdownBehavior.SYSSTOP:
os.system("sudo shutdown -h now")
elif behaviour is rydeplayer.common.shutdownBehavior.SYSREST:
os.system("sudo shutdown -r now")
def handleEvent(self, fd):
quit = False
# handle ready file descriptors
if(fd in self.irMan.getFDs()):
quit = self.irMan.handleFD(fd)
elif(fd in self.sourceMan.getFDs()):
self.sourceMan.handleFD(fd)
elif(fd in self.gpioMan.getFDs()):
quit = self.gpioMan.handleFD(fd)
elif(fd in self.osd.getFDs()):
quit = self.osd.handleFD(fd)
elif(fd in self.netMan.getFDs()):
quit = self.netMan.handleFD(fd)
return quit
def updateState(self):
# update playback state
state = self.sourceMan.getCoreState()
if(state.isRunning):
if(state.isLocked):
self.playbackState.setState(rydeplayer.states.playback.States.LOCKED)
newMonoState = state.monotonicState
if self.monotonicState != newMonoState:
self.monotonicState = newMonoState
self.vlcStop()
print("Param Restart")
if self.vlcPlayer.get_state() not in [vlc.State.Playing, vlc.State.Opening] and self.config.debug.autoplay:
self.vlcPlay()
self.osd.activate(4, rydeplayer.osd.display.TimerLength.PROGRAMTRIGGER)
self.gpioMan.setRXgood(True)
else:
self.playbackState.setState(rydeplayer.states.playback.States.NOLOCK)
if self.config.debug.autoplay:
self.vlcStop()
self.gpioMan.setRXgood(False)
else:
if state.isStarted:
self.playbackState.setState(rydeplayer.states.playback.States.SOURCELOAD)
else:
self.playbackState.setState(rydeplayer.states.playback.States.NOSOURCE)
self.vlcStop()
# print("parsed:"+str(vlcMedia.is_parsed()))
self.vlcPlayer.audio_set_mute(self.mute)
self.vlcPlayer.audio_set_volume(self.volume)
print(self.vlcPlayer.get_state())
# Step the state machine with a navEvent
def stepSM(self, code):
self.app.get_event(code)
if(self.app.done):
self.app.cleanup()
return True
self.app.update()
return False
# retrigger vlc to play, mostly exsists as its needed as a callback
def vlcPlay(self):
self.vlcPlayer.set_media(self.vlcMedia)
self.vlcPlayer.play()
def vlcStop(self):
self.vlcPlayer.stop()
def vlcAbort(self):
del(self.vlcMedia)
del(self.vlcPlayer)
del(self.vlcInstance)
importlib.reload(vlc)
self.sourceMan.remedia()
# self.sourceMan.restart()
self.vlcStartup()
def vlcStartup(self):
vlcArgs = ''
displaySize = pydispmanx.getDisplaySize()
vlcArgs += '--width '+str(displaySize[0])+' --height '+str(displaySize[1])+' '
displayPAR = pydispmanx.getPixelAspectRatio()
vlcArgs += '--monitor-par '+str(displayPAR[0])+':'+str(displayPAR[1])+' '
# vlc needs manually telling if using the second HDMI
if self.displayId == 7:
vlcArgs += '--mmal-display hdmi-2 '
if self.config.debug.disableHardwareCodec:
vlcArgs += '--codec ffmpeg '
# vlcArgs += '--gain 4 --alsa-audio-device hw:CARD=Headphones,DEV=0 '
print(vlcArgs)
self.vlcInstance = vlc.Instance(vlcArgs)
self.vlcPlayer = self.vlcInstance.media_player_new()
self.vlcMedia = self.vlcInstance.media_new_fd(self.sourceMan.getMediaFd().fileno())
def run():
parser = argparse.ArgumentParser()
parser.add_argument(metavar="config filename", dest='conffile', help="YAML config file to try and load. Default: config.yaml", nargs='?', default='config.yaml')
args = parser.parse_args()
print(args)
newplayer = player(args.conffile)
newplayer.start()
if __name__ == '__main__':
run()
