Problem with Reboot 202111051
G8YTZ
Post by G8YTZ » Thu Nov 18, 2021 10:29 pm
Since the recent update (202111051) if you reboot the Ryde from the Ryde menu via ssh the Ryde does not come back, you get an initial red screen "source not connected" then nothing, That's a problem when upgrading remotely or you want to reboot a repeater receiver.
I am using a 4k monitor, but with resolution set to 1920x1080@50Hz it is ok. I tried with GPU memory set to 256 and no difference.
Justin.
Re: Problem with Reboot 202111051
Post by G8GKQ » Fri Nov 19, 2021 12:27 pm
Hi Justin
None of the development team have 4k monitors, so this is tricky to bugfix. The Ryde update did not make any changes that were in this area of the code, but the action of updating the Ryde software also updates all the system software packages (to keep the security bugs at bay), so it could be an external change that has caused it.
From the ssh Menu, please could you run 2 diagnostics with the 4k monitor in its "failing" state?
First from the Utils menu, run Ryde Test and copy and paste the start-up and error code from the terminal window into a forum reply.
Secondly, from the Utils menu run the display test and copy and paste the response here.
G8YTZ
Post by G8YTZ » Fri Nov 19, 2021 8:16 pm
Thanks Dave,
I'll have to work on another one, the culprit (2GB memory) is now back at the repeater. I can still see that the Ryde performance is far worse than the Portsdown, I think you said it was running an older version of the receiver code, that would be a bigger priority for me.
The update I did was remote and the Ryde was set to CVBS output, after update it worked, then I re-made the settings again for the repeater and rebooted, after that it was dead. I ended up making a new SD card where is when I observed these issues. Everything was ok after I set to 1080/50.
Justin.
Post by G8GKQ » Fri Nov 19, 2021 9:42 pm
Hi Justin
OK - we await your test results.
Please could you expand on the perceived performance difference between the Ryde and Portsdwn receivers?
G8YTZ
Post by G8YTZ » Sat Nov 20, 2021 10:28 pm
Sure Dave, I'll do a video to demonstrate the problem. Basically on Portsdown the picture is rock solid, on Ryde it is full of glitches. When I mentioned it to Tim he said it was running an older version of Langstone.
G8YTZ
Post by G8YTZ » Sat Nov 20, 2021 11:28 pm
Dave,
here is a video showing the problem. It should be available on Youtube (unlisted) in about 15 minutes.
https://youtu.be/2zJnJSW0TpM
Justin.
G8YTZ
Post by G8YTZ » Sun Nov 21, 2021 3:36 pm
HI Dave,
I think you might be on the right track with suspecting VLC with H.262. Does VLC use a hardware H.262 decoder? Can I modify a config file to try sending the Ryde output to VLC on a remote machine as with the Portsdown?
This week I'll add an H.264 coder to GB3JV so it will have H.264 and H.262 on the mux, then I can try both channels.
I did as you suggested and tried HDMI 'safe' mode, but things were even worse running in HDMI 'Safe' mode.
I also tried:
1. Changing the GOP from IBBP to IBP to IB and just I. No decode was possible with I only, but IBBP was the best (normal mode)
2. Tried changing the resolution away from D1 (576) to HD1 and SIF, with lower resolutions the stability was perhaps only slightly improved.
VLC
I also ran the Ryde in "debug" mode. Here is the output, plenty of errors to see. The googled "Too high level of recursion" and there were plenty of hits for this error, one threrad suggested a graphics driver incompatibility.
https://forums.raspberrypi.com/viewtopic.php?t=257395
Justin.
pygame 1.9.4.post1
Hello from the pygame community. https://www.pygame.org/contribute.html
Namespace(conffile='/home/pi/ryde/config.yaml')
['dejavuserif', 'dejavusansmono', 'freesans', 'dejavusans', 'freeserif', 'freemono', 'droidsansfallback', 'notomono']
/home/pi/RydeHandsets/definitions
  IF offset: +5150000
  Frequency: 3404000
Symbol Rate: 2000
--width 1920 --height 1080 --monitor-par 1:1 --codec ffmpeg
[00b9c980] vlcpulse audio output error: PulseAudio server connection failure: Connection refused
[00bad870] vlcpulse audio output error: PulseAudio server connection failure: Connection refused
GPIO id: 5
Ready
start
['/home/pi/longmynd/longmynd', '-t', '/home/pi/lmmedia', '-s', '/home/pi/lmstatus', '-r', '5000', '-u', '1', '3', '-w', '1746000', '2000']
State.Stopped
lm started
1:1
state:{'state': 1, 'provider': '', 'service': '', 'modcode': None, 'pids': {}}
6:1746047
9:1998138
12:0
State.Stopped
state:{'state': 1, 'provider': '', 'service': '', 'modcode': 0, 'pids': {}}
1:4
6:1746046
9:1998138
12:0
state:{'state': 4, 'provider': '', 'service': '', 'modcode': 6, 'pids': {}}
1:4
6:1746046
9:1998138
12:213
state:{'state': 4, 'provider': '', 'service': '', 'modcode': 6, 'pids': {512: 2, 513: 3}}
State.Stopped
1:4
6:1746046
9:1998138
12:172
state:{'state': 4, 'provider': '1249MHz 23cm', 'service': 'GB3JV JO01AJ', 'modcode': 6, 'pids': {512: 2, 513: 3}}
1:4
6:1746046
9:1998138
12:192
Param Restart
1:4
6:1746046
9:1998138
12:189
1:4
[ad90aad0] ts demux error: libdvbpsi error (PSI decoder): TS discontinuity (received 10, expected 9) for PID 17
[mpeg2video @ 0xb150ecf0] Invalid frame dimensions 0x0.
[00d31d50] vlcpulse audio output error: PulseAudio server connection failure: Connection refused
6:1746046
9:1998138
12:179
[ad90aad0] ts demux error: libdvbpsi error (PSI decoder): TS discontinuity (received 10, expected 8) for PID 0
[ad90aad0] ts demux error: libdvbpsi error (PSI decoder): TS discontinuity (received 10, expected 8) for PID 258
[ad90aad0] ts demux error: libdvbpsi error (PSI decoder): TS discontinuity (received 10, expected 8) for PID 514
[ad919e68] main decoder error: buffer deadlock prevented
1:4
6:1746046
9:1998138
12:173
State.Playing
1:4
6:1746046
9:1998138
12:177
1:4
6:1746046
9:1998138
12:189
[ad4022f8] gles2 generic error: parent window not available
[ad403f70] mmal_xsplitter vout display error: Failed to open Xsplitter:opengles2 module
[ad4022f8] xcb generic error: window not available
[ad403f70] mmal_xsplitter vout display error: Failed to open Xsplitter:xcb_x11 module
[ad4235a8] chain filter error: Too high level of recursion (3)
[ad423048] main filter error: Failed to create video converter
[ad421a58] main filter error: Failed to create video converter
[ad403f70] main vout display error: Failed to create video converter
[ad403f70] main vout display error: Failed to adapt decoder format to display
[b151bcc0] main video output error: video output creation failed
[ad919e68] main decoder error: failed to create video output
[ad604810] gles2 generic error: parent window not available
[ad6045e8] mmal_xsplitter vout display error: Failed to open Xsplitter:opengles2 module
[ad604810] xcb generic error: window not available
[ad6045e8] mmal_xsplitter vout display error: Failed to open Xsplitter:xcb_x11 module
[ad620138] chain filter error: Too high level of recursion (3)
[ad61fbd8] main filter error: Failed to create video converter
[ad61f678] main filter error: Failed to create video converter
[ad6045e8] main vout display error: Failed to create video converter
[ad6045e8] main vout display error: Failed to adapt decoder format to display
1:4
6:1746046
9:1998138
12:185
[b1537900] main video output error: video output creation failed
[ad947b38] gles2 generic error: parent window not available
[ad947910] mmal_xsplitter vout display error: Failed to open Xsplitter:opengles2 module
[ad947b38] xcb generic error: window not available
[ad947910] mmal_xsplitter vout display error: Failed to open Xsplitter:xcb_x11 module
1:4
6:1746046
9:1998138
12:191
1:4
6:1746046
9:1998138
12:198
1:4
6:1746046
9:1998138
12:195
1:4
6:1746046
9:1998138
12:190
1:4
6:1746046
9:1998138
12:175
1:4
6:1746046
9:1998138
12:178
Param Restart
State.Opening
[ae30d9a8] main decoder error: buffer deadlock prevented
[ae31bbc0] main decoder error: buffer deadlock prevented
[ae30d8c8] ts demux error: libdvbpsi error (PSI decoder): TS discontinuity (received 0, expected 13) for PID 0
[ae30d8c8] ts demux error: libdvbpsi error (PSI decoder): TS discontinuity (received 0, expected 13) for PID 258
[ae30d8c8] ts demux error: libdvbpsi error (PSI decoder): TS discontinuity (received 0, expected 13) for PID 514
1:4
6:1746046
9:1998138
12:188
[a9709e00] vlcpulse audio output error: PulseAudio server connection failure: Connection refused
1:4
State.Playing
6:1746046
9:1998138
12:185
1:4
6:1746046
9:1998138
12:183
1:4
State.Playing
6:1746046
9:1998138
12:193
[ad604120] gles2 generic error: parent window not available
[ad603ef8] mmal_xsplitter vout display error: Failed to open Xsplitter:opengles2 module
[ad604120] xcb generic error: window not available
[ad603ef8] mmal_xsplitter vout display error: Failed to open Xsplitter:xcb_x11 module
[ad620020] chain filter error: Too high level of recursion (3)
[ad61fab0] main filter error: Failed to create video converter
[ad61f550] main filter error: Failed to create video converter
